You don't state the model of the control, and the key strokes to transfer programs from the Control to an external device varies between models. However, if you know the key sequence to be able to do this with your control, the following will work for all. Normally you will specify a program number at the control to transfer. If you give the program number as -9999 (O-9999), then the whole program memory will be transferred (except for protected program - parameter dependent). Accordingly, if you have more than one program in memory, transfer the whole memory and observe the format of the file received at the external device. You should find that all the programs will be received as one file at the external device (probably a PC). However, some Editor/Comms software will separate the files based on an incoming, preset character (normally "O" not Zero). Therefore you need to make sure the receiving software is not set in this manner. This one file that contains many files that was sent from the Control, can be sent right back (you may have to delete the existing memory - again, parameter dependent). I'm not suggesting that you do send this file straight back, but if you copy the format of the concatenate files received, then you should be able to transfer many files to the control in the format of one and have the control separate them.
Post here a short example of the file that you're attempting to send to the control.
Regards,
Bill
hello and thanks for everyones reply - i have been working with this idea and having no luck - 1st off im running 31I fanuc - I tried as mentioned above - I got everything to save with no problems but when i went to send back only sent 1st program - i have brought home small example from o-9999 program i saved
( FINISH BACK FACE )
(CNMG 431 LONG BAR)
( .015 RAD INSERT )
N757G43D22
N758G95G58G0X24.Y0B0
N759M112
N760G92S350
N761G96S270M03
N762U3.5Z2
N763M08
N764U3.6632Z.1
N765Z-9.5523
N766G01U3.8046Z-9.623F.0045
N767U5.136
N768G02U5.516Z-9.5258I0.K.2344
N769G01U5.316
( FINISH 3.88 ID )
N770G00U3.9554
N771Z-9.523
N772G01Z-9.623
N773G02U3.9262Z-9.629I0.K-.0206
N774G01U3.8921Z-9.6461
N775G02U3.88Z-9.6607I.0146K-.0146
N776G01Z-10.932F.008
N777U3.68
N778G00Z.1
N779M9
N780G0Z10.M5
N781M30
O5559
( FINISH SEAL BORES )
( .015 RAD INSERT )
N503T15M61
(1ST BORE)
N504G43D35
N505G95G58G0X-24.0008Y.0064B0
N506M112
N507G92S350
N508G96S300M03
N509U6.5Z2
N510Z.1
N512Z-7.1063
N513U6.7336
N514G01U6.875Z-7.177F.006
N515Z-7.3286
N516G03U6.1562Z-7.688I-.3594K0.
N517G01U6.0913
N518G02U5.97Z-7.7486I0.K-.0606
N519G01Z-8.0096
N520G03U5.9012Z-8.044I-.0344K0.
N521G01U5.7284
N522G02U5.6852Z-8.053I0.K-.0306
N523G01U5.6227Z-8.0842
N524G02U5.6048Z-8.1058I.0217K-.0216
N525G01Z-9.3886
N526G03U5.4674Z-9.5544I-.2344K0.
N527G01U5.2675
N528G00Z.1
N529M05
N530M9
N531G0Z10.
N532M113
N533X-42.
N534M30
( .015 RAD INSERT )
N503T15M61
(1ST BORE)
N504G43D35
N505G95G58G0X11.998Y-.0007B0
N506M112
N507G92S350
N508G96S300M03
N509U6.5Z2
N510Z.1
N512Z-7.1063
N513U6.7336
N515Z-7.3286
N517G01U6.0913
N519G01Z-7.89
U5.9
N528G00Z.1
N529M05
N530M9
N531G0Z10.
N532M113
N533X-35.
N534M30
I see something else i will try again tomorrow but will post this for now and check back in - thanks for interest
