TMMWV M-Dojo
- Jul 29, 2020
Hello all,
I have a Fanuc machine center with 31i - A5 controls. I have ongoing a revision to this M/C to be converted into a training machine, and in so doing now require some assistance.
I had it to where it would function correctly in Auto and Manual, but the Warm-up cycle would self-loop and repeat forever, although it would in fact perform this task. Like its warmup never hit M30 or something. So, had one of my guys to insert a counter into the PMC to prevent it from running warmup more than twice. We cycled power to the M/C after making program edits to this effect, and after restoring power it has been an absolute brick since.
I have the following errors in alarm panel:
PW0012 User I/O Cross Check Error (DCS PMC)
PW0013 User I/O Cross Check Error (PMC)
SV1068 Dual Check Safety Alarm
EX1084 KA15 Relay is defective (DCS)
EX1081 KA19 Relay is defective (DCS)
With Diagnostic codes:
0060 Emergency Stop (Operator's Panel)
0081 Start-Lock (Servo Unready)
0130 N Mode (Machining Mode Setting)
0151 Emergency Stop Worked
I have only Quick NC and MDI - I do not believe the PMC is communicating to all parties on the machine. I am confused; I have zero idea how pulling in a keep relay or attempting to write one parallel would have caused all of this. Any thoughts are appreciated, thank you in advance.
