Fanuc spindle fan motor replacement
Likes Likes:  0
Results 1 to 4 of 4
    Idaho
    122
    73
    19
    Default Fanuc spindle fan motor replacement
    The tiny little motor that spins the fan on the top of the spindle is making a terrible awful annoying scratch-your-nails-on-the-chalkboard like a dying squirrel sound when I start her up. It obviously needs replaced. Spindle is a 8000 RPM Cat40 and the fan number is A90L-0001-0514/R. Don't know the motor number since nothing is writen on it anywhere. Surprisingly heavy little bugger of a motor though.
    Anyone have any tips on replacing just the motor without paying an arm and a leg? The fan itself is fine.
    Figured I can't be the first machine owner that's had this little fan motor go out on them so am hoping there might be an aftermarket supplier out there that I can't find (that isn't from China on Ebay).
    Aug 2002
    West Unity, Ohio
    27,286
    7707
    9503
    FWIW - At least for the fans on the amps is concerned, Fanuc is as cheap of a source for them as anywhere.
    Don't know that I have ever replaced the fan on the actual motors on a Fanuc yet?
    Yes on Siemens - several times over ...
    Think Snow Eh!
    Ox
    Apr 2007
    Melbourne Australia
    297
    58
    44
    Fan on my robodrill spindle really annoyed me with its high pitched noise. I removed it and disconnected the fan behind the spindle also. Ran a flexi tube to the top from a old air con drum fan.
    Much much quieter and also more air flow!
    Feb 2006
    Republic of Texas
    2,893
    Spindle fans are a pain in the ass. I have replaced two with fans found on fleabay.. On another, I mounted a computer case fan on top of the red cap.
