Finally getting to the sub spindle on a Romi E320 with a fanuc 18i control. I noticed that the subspindle positioning is a negative number when activating the part transfer codes, I imagine that is because when I am positioning it within a program it is within the control of the main spindle? I am thinking about using a g55 for the sub and using offsets 21-32 for the sub tool offsets.. (turret has 12 positions) so tool one would be 0101 for main and 0121 for sub? is that a good way to go? one of the main questions is when in the g55 side of things working on the sub does the negative tool movement in z work the same, so negative is toward the chuck? This may all be wrong, and I am open to any easier ways to go about this, this lathe does have sync on the spindles, and I am just really trying to get my head around the offsets on sub lathes as I am very new to them.. The cam program I am working on can be set up to do just about anything, what is the best way to go? thoughts?
thank you
thank you
