cdmurphy
- May 26, 2008
- Meridian, ID
Hello all,
I'm trying to find out if there is any way to change the tool offset behavior of a Fanuc 10M based milling machine. As it is now, every time I command a G43 Hxx, the head instantly moves to correct the position by the offset amount. As you can imagine, this significantly increases the pucker factor when working on this machine. It doesn't matter if I'm in G90 or G91, or whether I also give it a Z value. What I want is for the offset amount to simply shift the coordinate position, or wait until a z move is commanded. I've looked all over the parameter manual for this control, and I can't find anything that seems to address this. There are two parameters, LGT and LWT, #60000 bit 2 and 3 that seem apparently address this, but the manual says they are only for the 10T/11T/12T series of lathe controls. I've tried setting them anyway, but they didn't have any apparent effect.
Anyone know what I'm missing? or is this just not possible on this vintage of control?
Cameron
Cameron
