Was just curious to know comparisons, pros & cons of these controllers.
And what you people rank them according to your experiences & in short why. ��
Seems to me like you are blaming a lot of things on Fanuc that are either implemented by the MTB or a product of your lack of familiarity with the control.A few months ago I got a Doosan DNM 5700 with a Fanuc 0i-M. The machine seems good, the control is bad. It works, but it's slow and counter-intuitive. Loading programs from a USB is much more complicated than it should be. It has a conversational control, but the techs didn't know how to use it and couldn't teach me. When using the probe/tool setting/tool changing menus, you have to enter numbers into fields before pressing the green button, and most of the time when you press the green button, it will give an alarm saying to press the reset button. Pressing the reset button clears all the numbers you just typed in and reloads the menu, which wastes a lot of time. This is a recurring theme with the control, it always needs the reset button to be pressed for some reason and this doubles the amount of time it takes to get anything done with the control.
Also, I have probing cycles integrated with my part programs to locate the parts accurately. The probing cycles are ridiculously slow, it takes 3 minutes to probe 4 holes for location because the machine just waits several seconds between lines of code in the probing cycle. This could easily double part cycle times for less complex parts.
So after 3 months you are ready to write off Fanuc? I guess you should have bought a Haas.This was my first Fanuc machine, it's a shame that most of the machines available in the US do not offer anything other than Fanuc because I will be seriously hesitant to buy any Fanuc machine in the future.
That may be bad switch, bad prox sensor....They had obviously never used my control that I have to hit Reset multiple times or it won't do anything. Or how sometimes it won't let me change Main Program unless I restart it and it all the sudden works. On my lathe that is also Fanuc I can't hit the turret jog more than 3 or 4 times in a row or it sticks and does this weird thing were it always goes back to the same station. Then I restart it and its fine.
My Haas has what I call the "running alarm" (I named it myself, it's not in the book).
I'm in a program, tool finishes, head goes up for the tool change and it just sits there with the spindle running. That's it. End of work, lol. Bottom of the screen says "running".
Reset button does nothing. None of the control buttons do anything. E-Stop does nothing. Can't jog, can't change modes, can't do anything.
The only way out is power down and power back up, home it out, pick up in the program where I left off and keep going.
It happens 2-3 times a year, has done it as long as I've owned it. Not repeatable, so not reportable...
(WTF does it mean "Number of Amps too small" when powering up ?
My Haas is a '93, so no NGC issues, it qualifies as an antique...Yeah, the NG control does have a tendency to go out for lunch and not come back from time to time.
The old control tough - in my experience anyway - is about as bulletproof as it gets. Between the 4 I have, not once did it need a reboot or a RESET even. Never.
Never seen that one, I must be using "big" amps, lol.Fanuc Oi ... cumbersome as shiit, rock solid when all is well but it also likes to be AWOL at times. (WTF does it mean "Number of Amps too small" when powering up ? )
All of them rank below Okuma's OSP control.
Better than Siemens or Heidenhain? I sure hope you are trolling...
Didja ever run a K&T 'D' ?OSP is/has been/remains head and shoulders above EVERY CNC control known on this here planet.
.Didja ever run a K&T 'D' ?
Notice
