Feed/Speed ADjusting for Endmill
Results 1 to 10 of 10
    Jul 2020
    CANADA
    Manitoba
    77
    28
    Default Feed/Speed ADjusting for Endmill
    Hello everyone.
    I have some issues with getting the feeds and speeds dialed in with end mills. I am running a 1/2 TiALN Coated Endmill in 1018 steel. Our machine is a NL3000y mill/turn center.
    I was running the end mill at 220 SFM, 0.0035 feed/tooth, recommended by local supplier. Full length of cut (1") and a .06 step over. After the first part, roughly 40 minutes of work I was seeing a dull edge and tiny, tiny chips on the flutes already, coating also seemed to be showing signs of wear. What are the first adjustments I need to make to prolong tool life?
    Also - if I make the switch to 1045 material, how much do my variables need to change?
    Thanks everyone for your help.
    Jan 2019
    Missouri
    419
    107
    104
    I run almost twice that SFM in 316SS.
    Jun 2012
    Michigan
    5,987
    5642
    3813
    Quote Originally Posted by jephw View Post
    Hello everyone.
    220 sfpm in 1018? With carbide?? 1" depth of cut and a .06 stepover is gravy.
    Find a new end mill supplier because that person is a moron.
    If this were in my VMC, I'd run it 3x faster (if not more) with that depth of cut and stepover.
    And that's with just a generic variable helix end mill from our resharp guys.
  4. Likes 5 axis Fidia guy liked this post
    May 2017
    Minnesota
    1,893
    2536
    1292
    Good quality endmills pay for themselves pretty quickly. I like Helical for steels and Ti. Also, as has been discussed recently in another thread, use a corner radius whenever possible to maximize cutter life.
    Oct 2015
    Oregon
    496
    239
    417
    If this is a mill turn center, perhaps the live tooling that holds said endmill is being over taxed.
    We all know that the further stick out, and large parts sometimes need to be backed off due to resonance.
    How do the cuts sound? Is it squealing or crunchy sounding during the cut?
    I will say, most of my 1/2" endmills are running in the 350-550SFM range depending on setup in 1018.
  7. Likes mhajicek liked this post
  8. #6
    Aug 2013
    Chicago, IL
    1,271
    915
    512
    Quote Originally Posted by Houndogforever View Post
    I agree...how does it sound? I believe those machines are supposed to have nice live tooling ability but that sounds a bit heavy for my lathes.
  9. #7
    Dec 2008
    New York
    10,400
    2715
    Hello everyone.
    obviously things are effected by
    tool length stickout amount
    tool holder length
    rigidity of machine
    rigidity of part has a effect
    hp of machine available (some rpm hp available can be much less than motor hp)
    part material and size of hard spots (some lots of metal might be 10x worst to machine)
    ability to hold part and distortion amounts by overtight work holding
    total tooling cost
    total scrap part costs
    it wouldnt be the first time a part in a mill turn setup moved during machining.
    obviously using higher hp and tons of cutting forces can cause problems.
    also some tooling might cost 2x more or 1/2 tool life but able to put a mirror finish
    on a part. just saying there are often tradeoffs for more important things wanted.
  10. #8
    Dec 2017
    CANADA
    Alberta
    70
    33
    15
    Hello everyone.
    What endmill is it? This sounds like a general purpose cheap endmill.
    If I were using a high performance variable flute end mill I would be starting in the 700 SFM, .0045 IPT range at that depth of cut and stepover.
  11. #9
    Jan 2007
    Flushing/Flint, Michigan
    10,580
    619
    8548
    A true TiALN coating will do nothing at 220 SFM in 1018.
    In fact it will hurt performance of the tool against uncoated.
    Some of the better (read higher priced) TiALN coats have TiCN mixed in which does like low surface footage,
    This done for two reasons, one to increase the bond to the substrate and two to help with many customers not making enough heat to convert the TiAln to Al2O3.
    If coated at this low speed I'd be in TiCN. Some would say TiN but TiCN likes the lower speeds better.
    Unsure how much of the 40 minutes is actual tool in the cut time.
    Some would consider this not that bad but I'd think you might be giving up a lot of part cycle time with SFM this low.
    Is the 220 a machine limitation?
    Bob
  12. #10
    Jun 2012
    Michigan
    5,987
    5642
    3813
    Oh god....he's back.
