gregormarwick
- Feb 7, 2007
- Aberdeen, UK
I'm about to drill a 5mm hole 400mm deep in a piece of 4140QT @235Bn.
I have a new gundrill here for the task.
A couple of weeks ago I did a similar part in the same material, with the same series of gundrill from the same manufacturer, but it was 280mm deep.
In that part I used 2800rpm (44m/min) and 33mm/min (0.012mm/r), which was right at the very low end of the recommended cutting data.
Running soluble semi synthetic coolant (Hysol XF at 5-7%), obviously not ideal but I can't swap the whole machine over to oil every time a need to use a gundrill...
It is 1000psi though.
Looking at the old drill, the edge is not in very good shape, and I'm concerned about the new drill getting the hole completed in the longer part.
Thoughts?
edit: clarified old vs new drill...
Thoughts?
