G00 Proto
Hot Rolled
- Feb 18, 2013
- Dirkdirkistan, ID
I have a part that I need to make with a 1/2" undercut (~1/2" width). The material is 8620 of unknown hardness. I am planning on using a 3"x 1/2" 20 tooth wheel cutter on a CAT 40 Arbor. I only need to make two (so far). If I run the book numbers I get 127 RPM (100 SFM). I don't plan on taking it all in one depth of cut, maybe .050 per pass. I don't know if I have any horsepower at 127 RPM. Anyone got any good suggestions. I only bought one cutter, so if it doesn't work, the world will end
