File output from Takisawa TCN-2100 with Fanuc Oi-TF. How to format?
Results 1 to 2 of 2
    Nov 2005
    Ohio
    310
    29
    Default File output from Takisawa TCN-2100 with Fanuc Oi-TF. How to format?
    Hello!
    I have a new Takisawa TCN-2100 lathe with a Fanuc Oi-TF control. When I save a file from the machine to a USB flash drive, the G-code appears all on one line....rather than consecutive lines.
    Is there a way to format the output?
    Thanks!
    Apr 2014
    673
    837
    425
    Sometimes it makes a difference which software you are using to read it. What are you using? Sometimes just switching from notepad to wordpad makes things work, according to my local Yamazen tech support guy.
    Otherwise, there might be a parameter that needs switching, I'm sure a Fanuc guru will be along at some point.
