Fillets v Chamfers on CNCd Parts
Results 1 to 20 of 20
    Oct 2017
    IRELAND
    9
    10
    Default Fillets v Chamfers on CNCd Parts
    Just looking to find out if it is easier to machine fillets or easier to machine chamfers on parts like aluminium (6061) and stainless steel (304, 316). I do Design Failure Modes Effects Analysis in a machine building company and am constantly coming acorss a mix and match of both. I'm thinking chamfers are the easier of the 2 to machine?
    Jun 2012
    Michigan
    5,445
    5091
    3417
    I assume you're talking about outside edges, then yes chamfers are typically the easier of the two because cutting fillets on outside edges requires a corner rounding form tool or a 3D toolpath.
    Although the corner rounding form tool cuts a fillet just as fast as a chamfer tool cuts a chamfer, you have to be a lot more critical when setting the tool and programming it or else the tool could gouge easily.
    tl;dr chamfer is more foolproof than a fillet for outside edges.
  3. Likes Booze Daily, PM2.5, mhajicek, PegroProX440 liked this post
    Feb 2006
    Republic of Texas
    2,718
    Not really any difference in CNC machining. Fillets create less stress points. We add fillets to nearly all the shafts and rollers on conveyors in food making machines that we work on.
  5. Likes PM2.5 liked this post
  6. #4
    Oct 2017
    IRELAND
    9
    10
    I've attached images of a part where I thought fillets were diefinitely not required on outside edges. I thought chamfers would be fine.
    The fillets on the inside would need to be hand filed I believe.
  7. #5
    Aug 2006
    greensboro,northcarolina
    2,557
    174
    676
    Fillets on turned parts, chamfers on milled parts. On your images, fillets could all be milled, but chamfers would be my preference. Milling fillets you have to have lots of different size corner rounding end mills. Chamfers , you only need a few. Tuned parts , you are programming the radius anyway , so size doesn't really matter. Any yes, inside radius on a turned part is stronger and eliminates a stress riser. My 2 cents.
  8. Likes Mtndew, PM2.5, SeymourDumore liked this post
  9. #6
    Jun 2012
    Michigan
    5,445
    5091
    3417
    Just remember, when designing a part, the prettier it looks the more it's gonna cost.
    Put a small edge break where needed to get rid of sharp edges, and a larger chamfer where needed for interference relief.
    Fillets on outside edges (of a milled part) look great on paper, but a chamfer will cost you less money to have it done.
    Edit: as per above, if it's a lathe part fillets are zero issue and make the part look REALLY nice.
  10. Likes PM2.5, Bobw liked this post
  11. #7
    Jun 2002
    CANADA
    British Columbia
    2,882
    2557
    Hi PM2.5:
    Those fillets will increase the cost of making the parts substantially, especially if you need them to be good looking or accurate.
    The fillets on the outsides of the block will require two setups to complete the part, and to make them accurately will require that the second setup be accurate with respect to the location and orientation of the part.
    By "accurate" I mean better than 0.0005" for the second side setup or else that underside fillet will look like a pig's breakfast, whether you surface mill it with a ball cutter or use a corner rounding cutter.
    A chamfer there is much more forgiving, so an ordinary vise with a stop will be more than adequate.
    On the cavity side, there are fillets you cannot mill as modeled, so if you NEED it to be exactly as modeled you have to sinker EDM it, and if you need it to be pretty good you can surface mill it with a tiny ball cutter and then pick out the corners with a file under the scope.
    That makes it a five hundred dollar part instead of a twenty dollar part.
    If you really don't give a damn, and all you need is for no one to cut up their hands when they handle it, you can just throw it in the tumbler or edge break it with a file.
    Now it's a twenty dollar part again.
    Cheers
    Marcus
  12. #8
    May 2017
    Minnesota
    1,429
    1841
    949
    Cheapest way is to leave the model sharp and put a note on the print: "Break all sharp edges."
    Second best is to model chamfers on external corners and fillets on internal corners. Allow enough tolerance on the fillets so they can use the corner radius cutters they already have, rather than having to order special ones just for you. And, this is a big one, corners in the X/Y plane need to be big enough to cut with a rotating cutter that has a reasonable length to diameter ratio; no .010" fillets 3/4" tall.
  13. Likes Camputer, ARB liked this post
  14. #9
    Nov 2014
    Florida
    5,676
    2251
    2827
    Quote Originally Posted by implmex View Post
    Hi PM2.5:
    Cheers
    Marcus
    As Marcus said, in your left view of part, top face, the sharp intersections would need edm, or a quick hack if acceptable, mini files to sharpen the radii that will be left between fillets into a *sharp* corner... Or just model the same fillet rad inbetween and then it's all 3d milled.
  15. #10
    Jun 2006
    Thunder Bay Canada
    1,865
    591
    326
    I've done both corner rounded fillets and chamfers. The corner rounding cutters work well but only if the surface is absolutely FLAT.The smallest variation in planar flatness (maybe you moved the part to a different vise)will cause a visible line from the edge of the cutter. This is not a problem with a chamfer. And any corner rounding cutter I've seen was HSS, not an insert cutter like most chamfer tools. (I'm guessing that solid carbide corner rounding mills are made somewhere but I've never used them.)
    So if you have any say in the design of the part I'd go with chamfers instead of rounds.
  16. Likes Bobw liked this post
  17. #11
    Feb 2020
    Washington
    155
    16
    144
    Quote Originally Posted by mhajicek View Post
    This. And if you really want to do us a favor, don't use fractional sizes, go up a little.
    ie. instead of .125 rads +/-.005, do .140 or .300 instead of .250. Our tools come in fractional sizes, so give them a little room to work.
    Again, this only applies to rads between walls, and not fillet rads on the bottom of a pocket. For those do the opposite.
  18. Likes mhajicek liked this post
  19. #12
    May 2002
    South Central PA
    14,227
    2633
    3955
    Quote Originally Posted by 706jim View Post
    Swiftcarb/Superbee makes carbide insert corner rounders.
    I wish someone made corner rounders that had a slight leadin instead of full 90° radius, would make applying radii much easier when it's just for appearance
  20. Likes 706jim, mountie liked this post
  21. #13
    Aug 2006
    2,557
    174
    676
  22. Likes mhajicek, Mud, EnderDRM, mountie liked this post
  23. #14
    May 2017
    Minnesota
    1,429
    1841
    949
    I was going to mention Harvey, RJT beat me to it.
    Quote Originally Posted by Camputer View Post
    I often use metric cutters for inch features, and vice versa. A 3mm (.118") endmill will cut a .125" radius fairly well.
  24. #15
    May 2002
    South Central PA
    14,227
    2633
    3955
    Quote Originally Posted by RJT View Post
    Perfect.
  25. #16
    Feb 2020
    Washington
    155
    16
    144
    We do as well here, but I've worked in shops with much less of a tooling budget and it was always a PITA. Opening up those interior rads is such an easy way to increase the machinability of your parts, but most engineers seem to like the hard numbers. I always try to design my tooling to be as friendly as possible.
  26. Likes mhajicek liked this post
  27. #17
    Jun 2011
    New Jersey
    1,256
    735
    504
    Quote Originally Posted by PM2.5 View Post
    On a lathe, you can do either rather easily. For Okuma it's G76 or G75 plus the "L" chamfer/radius amount. On Fanuc/Mits it's usually an "R" or a "C".
    On mill, a bit more, as you'll need either a corner rounder or a chamfer mill. The corner rounder needs a "little" but of care when programming/setting up.
    Generally I like to give radii on turned/milled parts whenever possible as it feels nicer in the hand. But, if a print says "chamfer" then chamfer it is.
  28. #18
    Aug 2014
    Noble, OK
    866
    67
    175
    Chamfers are easier to get a consistent surface finish from top to bottom. Corner radius cutters have a wide swath of SFMs from the bottom to the top of the radius. For example, we'll use a Harvey carbide 5/8" diameter 1/4" radius corner rounding EM with a .120" (or whatever the exact size is) nose. Using the major diameter of the tool, 5/8", for the SFM calculation at say 1000 SFM, you'll end up with only 200 SFM at the bottom of the radius. This can cause faceting if you're not running really low IPM. Using a large diameter nose and small corner radius helps, but then these are really only available in HSS.
  29. #19
    Nov 2013
    Utah
    5,078
    1329
    2873
    What does CNC'd mean? I can Turn a part, I can Burn a part, I can Mill a part, hell, I can even deburr a part. Deep thought--can I CNC a part? Computer Numeric Control is a description not a fucking verb.
    R
  30. Likes ChipSplitter, Bobw, TeachMePlease liked this post
  31. #20
    May 2019
    Michigan
    2,412
    1250
    1770
    R
    Prolly about the same as "lathing" a part from aircraft-grade bill-utt on a See and See machiner.
    That's even worser in my book!
  32. Likes litlerob1 liked this post
