I'm researching adding a CNC lathe to the shop sometime later this year. It will be used for prototyping, though if it would be suited for production that would be a huge plus should I ever get to that point. Most parts I would make are small, but I'd like to be able to turn shafts as well. So I think I could use more length than swing. The features I think I want are:
Searching some listings, I've found so far:
Okuma LB15
Mazak QT15 / QT20
Mori Seiki SL-15
Cincinnati Avenger 250T
Romi M17
Bridgeport EZPath II
Nardini Fast Trace
I'm not familiar with any of these, does anyone have any experience with them or have a recommendation for other models? Thanks.
- 7.5-15 hp 230v 3ph
- 20"+ between centers
- 2"+ bar capacity
- A turret would be nice but not required
- A decent control with conversational and g-code programming
- Can fit through a 8' x 8' garage door
- Smaller than 12'W x 6'D x 7'H footprint
- Budget is ~$10k for the lathe, a bit more if well tooled
- Parts and support available that won't break the bank
Okuma LB15
Mazak QT15 / QT20
Mori Seiki SL-15
Romi M17
Nardini Fast Trace
