First CNC lathe recommendations?
Results 1 to 17 of 17
    Jun 2020
    Ohio
    127
    35
    40
    Default First CNC lathe recommendations?
    I'm researching adding a CNC lathe to the shop sometime later this year. It will be used for prototyping, though if it would be suited for production that would be a huge plus should I ever get to that point. Most parts I would make are small, but I'd like to be able to turn shafts as well. So I think I could use more length than swing. The features I think I want are:
    • 7.5-15 hp 230v 3ph
    • 20"+ between centers
    • 2"+ bar capacity
    • A turret would be nice but not required
    • A decent control with conversational and g-code programming
    • Can fit through a 8' x 8' garage door
    • Smaller than 12'W x 6'D x 7'H footprint
    • Budget is ~$10k for the lathe, a bit more if well tooled
    • Parts and support available that won't break the bank
    Searching some listings, I've found so far:
    Okuma LB15
    Mazak QT15 / QT20
    Mori Seiki SL-15
    Cincinnati Avenger 250T
    Romi M17
    Bridgeport EZPath II
    Nardini Fast Trace
    I'm not familiar with any of these, does anyone have any experience with them or have a recommendation for other models? Thanks.
    Jun 2011
    New Jersey
    1,684
    912
    744
    Quote Originally Posted by jhov View Post
    • 2"+ bar capacity
    Okuma LB15
    Mazak QT15 / QT20
    Mori Seiki SL-15
    Romi M17
    Nardini Fast Trace
    Very familiar with a few.
    First off the Okuma LB-15 and Mori Seiki SL-15 are two top drawer machines. I own an LB-15 and the SL-15's older, big brother, the SL-3.
    Both are fully supported to this day for parts/service/applications.
    Both of mine are capable of holding tolerance over production runs.
    The other good choice would be the Mazak, as it's also supported.
    I'm not sure about the others. The Cincinnati Avenger was, in its day, quite the machine but parts/support are thin, as Cincinnati went out of business and third parties take care of parts. It's spotty at best, and non existent at worse. Personally I'd avoid it.
    Bridgeport, Nardini, and Romi are still around but I'm unfamiliar with them.
    My vote? Okuma LB-15, or Mori Seiki SL-15. Can't go wrong.
  3. Likes jhov liked this post
    Jun 2020
    Ohio
    127
    35
    40
    Thanks for the feedback. The Mori is on the top of my list. I'd still be curious to hear about the flat bed types if anyone has run one.
    Aug 2014
    Indiana
    172
    109
    275
    I have used both a LB15 and a Ezpath before. The LB15 is a rock solid lathe and very easy to program once you get used the IGF programming. The Bridgeport Ezpath is not as sturdy of a lathe compared to something like the Okuma but has hand wheels if that's your thing. I didn't care for the programming of the bridgeport, it's clunky if I remember right. If you are even thinking of any production go with something like an Okuma or Mori.
    Sep 2012
    California, Ventura county
    2,070
    957
    910
    Ok the Okuma, Mori and Mazak need about the same space as a full sized pickup
    Mazak probably the best conversational programming of the 3.
    If I had the room and power it would be a QT15.
    But all three are good machines.
    Oct 2017
    6
    • 2"+ bar capacity
    Okuma LB15
    Mazak QT15 / QT20
    Mori Seiki SL-15
    Romi M17
    Nardini Fast Trace
    Hello
    I have a Romi m17, it is new to me and am looking for someone to guide me thru the programing or start sequencing . It does not seem to teach very well from the manual .
    Apr 2021
    Minnesota
    The first of these lathes (and only)that I used was the ez path 2. I retired and bought an ez path 1 for my garage and....pretty nice for a home shop.
  9. #8
    Jun 2011
    New Jersey
    1,684
    912
    744
    Quote Originally Posted by sonofachip View Post
    Hello
    Anything on YouTube?
  10. #9
    Jun 2020
    Ohio
    127
    35
    40
    I'm still browsing for a lathe and came across a Takisawa TC-20. It seems to check all the boxes, its smaller than the Mazak, Mori and Okuma, and it appears to be supported by Yamazen which also supports my Brother S2B. Thoughts on the brand/model?
  11. #10
    Dec 2011
    Illinois
    411
    93
    130
    We've had one since new (1997, I think) and have no plans to get rid of it. It's been very reliable. The only problem I can remember is that we had to replace the turret encoder once. That's pretty darn good for nearly 25 years of ownership. Of course, there's been normal stuff like spindle belts, tach belt, and I think we had to replace the seals in the chuck actuator, but overall, I don't think you can beat it for reliability.
    There is some thermal growth as it warms up, but once warm, it holds size well.
    Being that it is a compact machine, the working area can be a little cramped compared to other machines, but you get used to it. It's really not that bad unless you're a giant.
    We also bought a used TC-1 (older and smaller than the TC-20) around 5 years ago, and it has been equally reliable.
  12. Likes BROTHERFRANK, jhov liked this post
  13. #11
    Dec 2013
    1,087
    293
    673
    The Takisawa TC-20 was a big seller. It's the predecessor of the new TCN-2100 machines. Many were installed here and still cranking out parts.
  14. #12
    Jun 2020
    Ohio
    127
    35
    40
    I'm sure this is a dumb question, but I'm looking at Miyano's wondering if something like a BNC-34 can machine long shafts in sections between spindles? As in:
    1) Machine the bar end to be held in the sub spindle
    2) Transfer the end to the sub spindle, use sub to pull the bar to max length
    3) Machine first section
    4) Unclamp sub, move to min position, reclamp and pull the bar to max length again
    5) Machine second section
    So I guess the real question is: can the work pass through the sub spindle?
  15. #13
    Jun 2011
    New Jersey
    1,684
    912
    744
    Most likely it can. I used to work for Doosan and our sub spindle lathes could do that, so I'm pretty sure Miyano can.
  16. Likes jhov liked this post
  17. #14
    Oct 2007
    SPAIN
    5,202
    994
    571
    If you've never used a lathe before, and are primary protyping and then running 20's or 30's of production, I'd go with a prototrack from South Western Industries.
    Simple easy control to use and you can wind the program through using just the handwheels (great confidence booster when you're learning).
    Depending on the type of work, a Dickson tool post will be fine and give you more clearances (as it's one tool at a time).
    But if you really want to think more unmanned for the future production, you can get a turret fitted.
  18. #15
    Jun 2020
    Ohio
    127
    35
    40
    Quote Originally Posted by barbter View Post
    I went through this thought process and had initially decided on just such a machine. But as I shopped around I found that the toolroom/teach styles lathes are just as much or more money as a full blown turning center. And while my prototyping only requires a few parts here and there, I would like to be equipped and have processes already developed to capitalize on a strong early demand should a product be well received. These days for consumer items, it only takes one popular youtuber or blogger to plug your product and all of a sudden orders can pour in and overwhelm anyone who did not prepare for success.
    So I'm now looking for as much capability as I can afford; which appears to be early to mid 90's dual turret/spindle turning centers and mill turn machines such as:
    Mori Seiki ZL-15 series
    Okuma LR-15 series
    Okuma LU-15 series
    Takisawa TM-15 series
    Miyano BNC, BND, and LD series
  19. #16
    Oct 2007
    SPAIN
    5,202
    994
    571
    Okuma LR-15 series
    Okuma LU-15 series
    Hmmm....not criticizing you for one second, but you're going from a really easy peasy basic machine, to something with a LOT of moving parts and engineering (process and programming) "issues" that you just won't understand at this stage.
    Added into the mix that lathes get crashed for a past time, if you're looking at that old a machine, you really have to know what you're looking at.
    Or you've just bought a boat anchor.
  20. #17
    Jun 2020
    Ohio
    127
    35
    40
    I agree, and I'm quite nervous about it. It's why this thread is 7 months old and I'm still researching, learning all that I can, and wringing my hands over my options. At least I have the advantage of not needing something immediately, so I have time to learn and hopefully the right deal for the right machine will come. I've been through this process before with my S2B and it worked out better than I could have ever hoped, thanks to the help of members on this board.
