Vorsprung
- Feb 7, 2014
- BC, Canada
I'm currently looking at the feasibility of bringing our currently outsourced machining in-house, but trying to find the right machines. We work almost entirely with aluminium, with occasional steel fasteners and small parts. We're not a job shop, just looking to manufacture our own designs ourselves. Footprint is not an issue for the time being - may turn out to be down the track but not now.
Turning capacity needs to meet the following:
Y-axis/C-axis capable. Interpolation between the two would be very handy too - though as I'm not a machinist myself, I'm not sure whether that's a control/CAM issue or a hardware thing?
63mm (2.5") bar feed capable
Part lengths of up to 500mm (20") ideal. Nothing we currently make is more than 120mm long, but future plans include longer parts.
Unsure as to whether a secondary spindle is a good idea/necessary. Many of our parts require multiple setups otherwise, but thin walled aluminium (50mm diameter tubes, 1.3mm walls for example) - am I wasting my time with this? Seems like crushing the parts is likely to be an issue on the second spindle, unless we leave workholding material at the outer end of the first part after the first op, and part off later. Currently these parts sit at about 110mm long, max OD just under 60mm.
Milling capacity needs to meet the following:
5-axis capable, at least as a 3+2/4+1. No current need for complex 5-axis contouring but that's also partly because so far we've designed around largely orthogonal operations. My understanding is that most contouring work like that is also extremely slow (please correct me if I'm wrong) so we would typically try to design in such a way that we could avoid that.
Workpiece sizes are small. So far, all foreseeable parts would fit within a 100mm (4") cube quite comfortably. Larger parts may happen down the track but they aren't on the cards right now.
What I've looked at for the lathe:
Haas DS30SSY. Covers everything I need, but I seem to recall reading somewhere that the 2nd spindle on those isn't quite as useful as you'd expect it to be. Can anyone elaborate on this? The HFO sales rep up here in BC mentioned some weird thing about the turret tooling not actually aligning with centre on the 2nd spindle - that doesn't seem like it could be possible since, unless I'm retarded, the 2nd spindle has to be coaxial with the primary spindle in order to exchange parts? Tool holders on the back side of the turret in a different spot or something? Or have I somehow gotten my wires crossed? Also I notice that the "control type" listed for the sub spindle is listed as "positioning only" not "positioning and interpolated motion" as per the primary spindle. Does this mean no C-axis on the 2nd spindle, or no Y-axis too? Any other feedback on the Haas lathes in general? Seem like the lowest-priced options I've found - a few people have mentioned that most Haas stuff isn't really built for 24/7 production, but that isn't likely to be an issue for us in the immediate future.
Okuma Genos L200E-MY: bit more expensive than the Haas, from memory I think the rep (who is also the Haas rep) said they're typically about 15% more than the Haas equivalent. This is only a single-spindle unit too, to get a sub spindle it'd be the L300-MYW which only has a 150mm workpiece length - not really long enough for what I'm looking to do. I have way less info on these than I do the Haas.
Haven't had a proper chance to familiarise myself with their range but the Doosan Pumas look decent too and almost everything I've read about them has been positive. How do they stack up price wise? What else should I check out? Anticipate them running 50-60hrs per week, not 24/7 operation.
As far as milling goes, I've checked out the following setups:
Haas DT-1 with 100mm trunnion 5th axis
Haas VF2TR, with the 160mm trunnion table 5th axis
DMG Mori Milltap 700 with 5th axis option. Not entirely sure what pricing is on this but probably a bit more than the DT-1 or the VF2TR? Without the 5th axis option it looks to actually be fairly comparable with the Haas units.
DMG Mori EcoMill 50. 5 axis standard, reasonably cheap for what it is, but more expensive than the others
Heard a few bad things about the Haas trunnions not being particularly robust. Mori's reputation is a bit better but the EcoMill and Milltap machines seem to be built for the lower-end market.
Feedback? Anything else I should be checking out? Doosan? Fanuc Robodrill?
