Fix a coolant drip with flex seal?
Results 1 to 20 of 20
    Nov 2018
    ALAND ISLANDS
    156
    112
    77
    Default Fix a coolant drip with flex seal?
    You know , I have that that one drip on a otherwise sealed up mill enclosure just looking for the temporary ( permanent) fix.
    So the add goes across the tv screen and i just wonder..... maybe. Not wanting to tear the enclosure apart and seal it right until I have time to do it.
    Any tries? Did it hold up to coolant?
    Jun 2014
    New Jersey
    256
    270
    150
    well, if you cleaned up the area with mineral spirits , then acetone, you may be lucky enough to get a good bond.
    if you get a good bond, I see no reason after the cure why it wouldn't hold up.
    so yea it should hold up.
    Jun 2015
    Minnesota
    741
    12
    261
    I used some of that tape to seal a small hole in the bottom of roll out coolant chip tank. Held up great, even with the abuse of scooping out chips many times. It only recently finally let go after what, maybe 3 years? And that's after drowning most the time in Qualchem 251C.
    Apr 2020
    Ohio
    948
    912
    332
    Plasti dip in a paint can (not the spray paint version) I would think is worth a try and yes x1000 agree with woodchucknj on getting it CLEAN!
    I used flex seal 1 Time in my life, on a gutter seal that was leaking.
    Didn’t work for a shit!
    And I’ve used plasti dip, rtv, jb weld and silicone caulk Successfully time and time again.
    From my little experience with flex seal I think it’s just plasti dip with a better sales pitch
    Nov 2018
    ALAND ISLANDS
    156
    112
    77
    Thanks for the reply’s . I would clean good for sure otherwise no chance.
    Now can this get sidetracked to a political shitshow like most the other post? Lol
    Apr 2020
    Ohio
    948
    912
    332
    Quote Originally Posted by Turbowerks View Post
    Oh it can get sidetracked! Don’t test it!!!
  7. Likes Turbowerks, Chris59 liked this post
    Sep 2017
    Wisconsin
    1,247
    325
    780
    Try Permatex Ultra Black RTV. I've had it seal up oil pans on race motors that have positive crankcase pressure and high oils temps.
  9. Likes Turbowerks liked this post
  10. #8
    Jun 2006
    Near Seattle
    5,210
    3791
    1566
    Some folks in the RV community speak well of eternabond - used mainly to seal leaks in RV roofs. I have not used any of these things, I only mention it as "another thing to try".
  11. #9
    Nov 2018
    ALAND ISLANDS
    156
    112
    77
    Quote Originally Posted by bryan_machine View Post
    Ya that butil rubber tape has to be the worst crap to peel off of a rv to do a repair on until you want it to stick seems like. But they do have some amazing stuff for bonding and sealing plywood and tin together
  12. #10
    Sep 2015
    604
    23
    292
    I agree with the RTV ultra black silicone. But the reliability of all any of these options depends on proper prep work. Clean the area well with solvent and give it a final wipe down with brake cleaner (acetone in a convenient spray can).
  13. #11
    May 2002
    South Central PA
    14,555
    2798
    4288
    I sprayed some of the aerosol flex seal on a spot inside an enclosure just to see how long it lasted. It crumbled into a mess in short order.
  14. Likes Homebrewblob, Ox liked this post
  15. #12
    Aug 2005
    CT
    8,267
    443
    2168
    Sure it can! Just change the title to say White Flexseal and sit back/watch!
    On the serious side though, this stuff is pretty amazing.
    Did not use it on coolant yet, but recently sealed up a Wire EDM water tank that is made of steel ( whatever Brother was thinking with the HS3xxx series )
    I've used plastic mosquito net to build up a few edges and patch seriously large ( 1-2" dia ) holes.
    There was no way to absolutely clean up the rust, so did the best I can and then brushed the stuff on it.
    The one I used came in a can and it says it's the "thicker" formula, but it's still has a pretty darn low viscosity and takes a bit to dry.
    I ended up brushing the first layer onto the screen patches, and kept on going back every half hour to an hour to make sure there were no big drips.
    Then the second day ( some 18 hours later ) it was cured to a consistency that was still fairly soft but no longer pliable.
    I then added a second layer with brush-on and extras where needed and let it flow around a bit.
    Then after another 24-32 hours of curing it became thick and fully adhered. I have tried to pry it up in some places to see how well it stuck. Well, It was stuck!
    In any case, I would recommend that you go ahead and try, but please get back to us about how it worked with coolant!
    In my case with plane water and rusty surface, it is flawless.
  16. #13
    Jan 2016
    151
    17
    83
    Try Dow 732. Wipe the surfaces down with isopropyl alcohol first if possible for the best adhesion. Worked great for me.
  17. #14
    Feb 2004
    New York
    3,942
    1196
    1955
    I think it will seal well, but being rubber based will not hold up to many coolants for a long time.
  18. #15
    Nov 2018
    ALAND ISLANDS
    156
    112
    77
    Getting back on the flex seal tape , i cleaned it as good as i could brake cleaner 3m , dried with air, came back with 99 % isopropyl, air dried , stuck the tape thought is was on for life!
    Used it for a week no drips thought i had it. Over the weekend came back on monday an the tape was lifting on the edges, by tuesday it was pretty much shot. This was using the schaeffers syncool 411 coolant with di water.
    Guess I’ll pull the panels and seal it right Fix a coolant drip with flex seal?
  19. #16
    Oct 2009
    Oregon
    5,861
    6357
    3225
    If you are certain you will never, ever need to remove the parts again go down to your local Ford dealer and buy a tube of the shit they use to glue on the 7.3 Powerstroke oil pans.
    I shit you not if it leaks that stuff will seal it.
    Used it to seal the pan on a Big Cam Cummins leaking a coffee can a minute.
    Used it to seal a Cat D7 that blew a headgasket externally shooting out a stream of coolant.
  20. #17
    Feb 2014
    Southern Illinois University
    94
    29
    Quote Originally Posted by Garwood View Post
    Don't believe him? Try and take the pan off one without turning it inside out. Holy shit is that stuff tough.
  21. #18
    Feb 2006
    Republic of Texas
    2,847
    We have used Permatex "Right Stuff" to seal a number of shields and coolant pans. No leaks after 3 years.
  22. #19
    Sep 2015
    Ohio
    1,667
    1113
    1729
    I've used JB Weld before. Just mixed it up and smooshed it in there.
    No more leaks.
  23. #20
    Mar 2021
    Wisconsin
    Never used the tape, but coolant eats the spray stuff like it’s nothing. ATV silicon caulk seems to work the best for semi-permanent seals that can also be removed if you need to. Coolant eats that too, but it should last for a year or two.
