Fixed diameter collets for flexible parts?
Likes Likes:  0
Results 1 to 10 of 10
    Jun 2010
    Connecticut
    481
    17
    25
    Default Fixed diameter collets for flexible parts?
    I'm looking for a solution to clamp down a thin walled needle bearing outer ring to force it to a given outer diameter and high roundness. (12mm nominal)
    A self centering four or three jaw chuck where the jaws bottom out and a 11.998mm hole ground is a solution but I would rather have a collet solution if possible.
    In a way it would be like an emergency collets with the pins left in during use. Are there any collets that are design to bottom out like this when closed? I'm considering bonding shims in a 5-C and then grind it but any "home made" solution is probably way costlier than getting something made by someone doing collets for a living.
    Jun 2012
    Michigan
    5,846
    5526
    3737
    What about full wraparound jaws bored to the size you want?
    Dec 2016
    174
    35
    50
    Get a set of S20 collet pads. They also make master jaws for a 3-jaw chuck so that might be the least expensive way to get started and could be adjusted to close tight then hard bored.
    Jun 2008
    Roanoke, VA
    759
    198
    302
    Have you considered pressing it through a sizing ring instead?
    Aug 2002
    West Unity, Ohio
    27,287
    7708
    9503
    A centerless grinder would be more better, quicker, and cheaper.
    Think Snow Eh!
    Ox
    Jun 2010
    Connecticut
    481
    17
    25
    They are centerless ground as is. We need to measure the apparent diameter over the rollers.
    Jun 2010
    Connecticut
    481
    17
    25
    Yes, It just to tedious to press them in and press them out doing large numbers of them. I'm also concerned over scoring.
    Jun 2010
    Connecticut
    481
    17
    25
    Got a quote for a nice air powered chuck. Certainly an option but it is a bit on the expensive side vs a collet fixture.
    Oct 2010
    Dewees Texas
    3,116
    33
    1026
    I had Hardinge make me some special collets for thin walled aluminum. We used .006 wide slots. They told me at the time they could make them with zero wide slots. Not sure how you to deal with the spring back.
    Jun 2010
    Connecticut
    481
    17
    25
    Quote Originally Posted by FredC View Post
    Thanks Fred, I will check with them. Sounds what im after. It is just for measuring the installed clearance. Needle roller bearings has a huge range. You can measure it by pressing it into a ring but thats a Schrödingers cat thing. The Manufacturers state not to use after that... i like to genly Squeeze it round and then gage them and sort by clearance.
