JP Machining
Stainless
- Jul 15, 2006
- Wisconsin
So a month ago I made some delrin parts with a 28mm bore something like 4" deep with a diameter tolerance of +/- 0.001". I am confident they were in spec when they left here, after having sat on the bench for a day and inspected again. Now a month later customer is saying they are 0.0009" under tolerance limit.
Ok, maybe I should of machined them right to the max tolerance anticipating some shrinkage, whatever. I've done similar before and they stayed put. Maybe the current high humidity around here caused it, I don't know
Question is how to enlarge the bore without messing them up, complicated part can really only hold on one end now, just worried about dialing the existing bore in dead nuts and then reboring without ruining finish too.
How bad would a reamer work? I assume ball sizing doesn't work in delrin. I dont think they would like lapping grit embedded in the bore either. Guessing I'm left with boring or reaming and just spending alot of time making sure each part is lined up perfect before starting
