Hi
I'm toying with the idea to make a fixture like this:
Quick Change Receiver and Blank Pallet | Mitee-Bite Products LLC.
A base plate and taper/diamond pin, with some expansion clamps.
Got more and more small parts to machine.
And for some bigger parts I need to make a fixture because I can't hold them in a vise.
Besides I can run more parts at the same time. Setup is also faster. And I can make one pallet ready when the other is in the machine.
But instead of using a aluminum base plate I'm thinking about steel. So there's a minimum galvanic corrosion between the machine table and fixture. I'm a bit scared that a aluminum base will damage the bed. And a steel fixture is more durable.
I know some zero point systems are made out 1.1730. steel.
What do you guys recommended on how to make the base plate?
I'm thinking about machining the plate, give it a heat treatment and send it to someone with a surface grinder?
