Fixture Plate Question
Results 1 to 16 of 16
    Apr 2012
    Dallas TX
    86
    9
    29
    Default Fixture Plate Question
    So I am making a semi quick change fixture pallet system for my Haas super mini mill. My table size is 16" X 12". I ordered 14" X12" X 1" thick MIC-6 aluminum plate for the project. I would have gotten bigger than the travel range, but I wanted to leave my Renishaw tool setter on the table.
    What type of locating pins would you suggest? I have seen the combination of diamond and round pins in many of the pictures I found. What size pins should I use, and how many? Also, would it be better to just use the two Kurts and clamp the plates with both vices?
    I would love to order ball locks or some fancy quick change fasteners, however, I think I'm going to go with standard 1/2" screws of some type. I have the probe, and if something doesn't locate precisely, I could always adjust. I am planning on having 3-5 plates, with my vices mounted on one of them.
    Any suggestions or feedback would be great.
    Sep 2007
    Baltimore
    17
    31
    Check out Jergen's Work Holding Systems. They make everything you are describing. I have used them in the past for quick locating dedicated fixturing.
    Jul 2009
    Peoria, IL
    11,736
    51
    8981
    Does your table have a slot going in the "Y" direction?
    Sine keys are a pretty simple way of locating fixtures to the machine table. If the slots are in good condition, you can hold a few .001s. There are several kinds of keys, some fit in a reamed hole, some in a slot.
    What is your expectation of tolerance/repeatability? You might be surprised how loose the tolerance is on Mic-6 plate. It is also pretty soft, even on aluminum terms, so it will not last forever.
    Blanchard ground steel plate is kind of the industry standard for things like this. In the sizes you are talking about, it might actually be cheaper than Mic-6.
    Jan 2009
    842
    151
    207
    You can get a long lifespan out of a MIC 6 plate. Mine is pretty much dead flat after 6 years of use...Last shop I was at has MIC 6 plates on their machines that are decades old.
    Jan 2007
    Ontario, Canada
    540
    219
    507
    We use a lot of mic 6. I just unloaded 2 4x8' sheet's of it this morning. It lasts, but it all depends on how you treat it. For high use stuff, we get it hard anodized, but for 1 off, and low use just use as is. If you're slamming them on and off the table, in a "every second counts" type scenario, I would choose another more suitable material.
    Mar 2011
    NH USA
    164
    17
    38
    We used speed loc fasteners for ours and have been very happy with them. 4 per plate, as manufacturer recommends.
    As to Blanchard ground plate they can vary by quite a bit in thickness/parallel. You really can't probe your way out of the vise bed being not parallel to the table. If it were my plates I wouldn't rely on Blanchard ground. If it needs to be flat it needs to be flat. Mic6 plate usually needs a skim to make it flat as well.
    Jul 2009
    Peoria, IL
    11,736
    51
    8981
    Quote Originally Posted by escott View Post
    Who are you having do your grinding? A blanchard could hold .001 on flatness and parallel on the size plate we are talking about. MIC 6 is supposed to be .005, but I've seen more than twice that.
    Apr 2012
    Dallas TX
    86
    9
    29
    My slots are in good shape. Got my machine new in January. Jergens stuff looks great, the problem is the heads on all their ball locks and pins are giant. Not to mention their stuff is expensive. I should be able to get within .005" as long as I square off everything and make sure my pins are positioned right. I don't need them to last more than a year or maybe two. I will be using mitee bites, and other methods of clamping on the plates. one plate will have a vise or two, so if I need a bit more rigidity, I can get it. I'm by no means the expert here, but these plates are for parts I'm currently holding in 6061 soft jaw, and I think the Mic-6 should be sufficient. The link below is more of what I'm looking to do. I will probably use a different type of fastener on top. Any idea wha size those locating pins might be?
    Mitee Bite Clamps and Shopmade Pallet Fixture for Small Parts « CNCCookbook CNC Blog CNCCookbook CNC Blog
    Jan 2011
    SF Bay
    372
    50
    215
    We've got Jurgens ball-locks on our Daewoo, and it's saved our tails more often than I can count. Well worth the money. The carrier plates repeat to within .001" without even trying, even when they're cranking down a plate with 3 Kurt 645's on it. You can make your own carrier plates, but I'd buy a master plate from Jurgens. Yeah, it's pricey, but it lets you change out jigs in seconds without worrying too much about location. Yes, the Jurgens heads are giant. Nature of the beast I'm afraid.
    Apr 2012
    Dallas TX
    86
    9
    29
    Thanks for the feedback.
    What size and shape locating pins would you recommend for a 14"x12"x1" plate?
  11. #11
    Jul 2002
    Phoenix, AZ USA
    1,732
    56
    213
    I would use .500 diameter locating pins on that size... I made a plate system for a 40x20 machine years ago and think we used 3/4" at the time.... but the plates were more like 16" x 24". We had a job that repeated with 4000 pcs. per month, we were able to load like 40 some parts on the plates each load. We did use blanchard ground steel plate for the sub base, and steel plate that we hollowed out with pockets underneath for the changeable plates... although Mic 6 would have been sufficient, and easier on the operator.
    To hold the plates in alignment we used the identical situation you linked to, one round, one diamond pin and location was always within tenths.
    LOCATORS, LOCATING PINS, Bullet-Nose Pins :: Carr Lane Manufacturing Co.
    To hold the plates down, we used hydraulic clamps, they are sold by Carr-Lane and are actually built by Rohmheld, these aren't exactly like them, but the closest I could find (I built mine 20+ years ago, so they might not have the exact same units):
    SWIFTSURE
    We had an air over hydraulic power unit and wired in a relay for air blast to the unit and could M-code the clamp/unclamp portion of the process. It all worked great until the customers needs went from 4000 to 6000 per month to about that amount twice a year....
  12. Likes Blackdiamond liked this post
  13. #12
    Mar 2011
    NH USA
    164
    17
    38
    Quote Originally Posted by ewlsey View Post
    Key word "could". Get a blanchard ground plate from a common supplier, throw it on a surface plate and actually measure it. I'm aware of what can be held, but I also trust my indicator.
  14. #13
    Jul 2009
    Peoria, IL
    11,736
    51
    8981
    What is your "common supplier?
    All I know is that if I buy a flame cut 1" or thicker plate, get it stress relieved, and take it to my local grinder, it comes back to me within .0015/12 on flatness and parallel up to 40" corner to corner.
    I can have the flame cut made in any shape, with windows and complex curves. The MIC-6 has to be milled or cut on a plate saw (possibly water jet, but that will cost you). I have milled some and it pretty much sucks to machine. It is very gummy and soft.
    The only time I use MIC-6 is for leak test fixtures where I need corrosion resistance and no real strength.
  15. #14
    Apr 2012
    Dallas TX
    86
    9
    29
    Brian,
    Thanks for the great answer. Sometimes I think it's a guys compete on who provides the best answer. The info I was looking for was pretty simple, except I didn't really know because of all the other input I had received. The parts being machined are .2" thick and will be held with mitee bites. Using steel would be great, but, unnecessary for this application. I will be surfacing and pocketing .01-.04" deep and I don't need them to be able to clamp the empire state building . I'll post pictures when I get it done. (even though they will be criticized, cause everyone has their own opinion, and someone will always do it different
    Thanks for all the info guys.
  16. #15
    Jul 2002
    Phoenix, AZ USA
    1,732
    56
    213
    No problem, just been there, done that... and this was back in the day (probably late 80's) when the commercially available pallet changers were non-existent. It works well, and can really speed things up if you have repeat jobs... we made other fixture plates and used the same base unit on the mill quite a bit.... although it was really too large for manually putting plates in and out. I could see a smaller version being very handy.
  17. #16
    Mar 2002
    Brisbane, CA, USA
    1,670
    73
    194
    If you are bucks down, if you search "subplate" on this forum you'll hit a lot of good suggestions on making your own subplates and pallets using standard tooling components.
    I like and "borrowed" the suggestion that ARB made in the thread below to use a plate with a grid of tapped holes with a bored top so that you can use standard shoulder bolts to both locate and clamp fixtures and pallets.
    Subplates
    Paul T.
    Power Technology
