Cha0ticBliss
- Jan 18, 2019
Does anyone have any tips or tricks on maintaining tight flatness requirements on 6061-T6 (or T6511) aluminum?
Parts are generally around 12"x 12" and at least .100" thick on the majority of the part. Most have pockets and or ribs so lapping is not an option for most. I normally see .002-.003" flatness on a part this big, but have been no-quoting several jobs lately that call the same flatness on a part twice as long.
I've seen that dull cutters or aggressive cutting can definitely induce stress, but beyond that it seems like a each lot of material behaves differently. Some hardly move after machining while other lots can bow 4 times as much with the exact same process.
I spoke with a heat treater and they suggested heating the raw material to just below the tempering temperature to relieve any internal stresses so will probably give that a go, but am open to any other suggestions!
