Flexbar flycutter advice
Results 1 to 18 of 18
    Nov 2014
    Florida
    5,130
    2040
    2501
    Default Flexbar flycutter advice
    Has anyone used a Flexbar brand flycutter? Any recommendations for speeds and feeds? It has 2 tool bits oriented vertically. Will be machining aluminum, just cleanup facing, .01" or so.
    Flexbar 6" Simul-Cut Fly Cutter Tool - 19006 - Penn Tool Co., Inc
    Feb 2013
    Idaho
    778
    181
    901
    Yes, I have some data. One of our senior machinists used to use one on a Bridgeport to deck off large plates because he could do it in one pass. One day he went to clamp the quill lock and his hand slipped and went straight into the cutter. We found one of his four fingers in rafters about twenty feet away. He was spinning the cutter at 2400 RPM, you may want to go slower or faster depending on the hardness of your fingers.
  3. Likes TeachMePlease, chet, Garwood, greggv liked this post
    Sep 2016
    Tennessee
    57
    45
    19
    Quote Originally Posted by G00 Proto View Post
    oh my gawd
    Jul 2020
    459
    170
    89
    fly cutters work extremely well, I have not used this model, but it does not look beefy enough.
    you will need a roughing and finishing pass, I not sure I like these double cutters, I like to measure my parts
    for the finishing pass. I use a drop indicator to get an exact DOC for final size. old school.
    I seen accidents over the years. and it's not trivial. that's why the new VMC have sliding doors to activate (start)
    the controls, I like the new stle VMC and CNC lathes for that reason, safety, safety, safety, I started out on a bridge port style mill, and an old turret lathe,
    and it was common back then for old timers to have missing fingers. engine lathes are the worst, because
    always getting near the chuck spinning at high RPM. but the old sheet metal brakes were the worst.
    I seen operators loose they entire hands due to lack of or altered safety devices.
    Nov 2014
    Florida
    5,130
    2040
    2501
    This will be in an enclosed CNC. I know there was a video out there where a cylinder facind head (?) went through an entire building. I don't think the flexbar has nearly enough mass to do that, but I know it could cause some serious damage if the rpm gets up there. Unless someone have some definitive numbers we will likely just start at 2-300 rpm and work our way up to our comfort level.
    And yuck, that's gotta suck to lose fingers.
    Sep 2010
    Oklahoma City, OK
    5,132
    941
    2166
    ...We found one of his four fingers in rafters about twenty feet away....
    So of the 4 he lost only 1 was found in the rafters? Or he only had 4 to start and is now down to 3?
  8. Likes Mtndew liked this post
  9. #7
    May 2019
    1,172
    437
    607
    This shit's chess, it aint checkers!
    I'm far from a safety oriented individual but tools like that make me slow down and think twice, maybe even thrice. But I don't doubt it works great when used correctly. I'd be interested so see the results.
  10. #8
    Jan 2007
    Flushing/Flint, Michigan
    9,152
    502
    7576
    This or homemade versions work fine for me.
    Advantage one over a normal single flycutter is balance.
    I set one tooth .001 proud or high to control the finish.
    Bob
  11. Likes Hardplates liked this post
  12. #9
    May 2011
    New Jersey
    2,588
    236
    1401
    And this is why I don't like fly cutters. Next to a lathe probably the most dangerous thing you can use in a machine shop. The old guy at work swears by them and refuses to use shell mills. I am the exact opposite.
  13. #10
    Nov 2014
    Florida
    5,130
    2040
    2501
    Quote Originally Posted by Hardplates View Post
    I'm not happy about having to use one, but alot of the parts we make have high cosmetic requirements and the bossman don't like to see "lines" where a tool has taken multiple passes (I know, I know, but he signs my paycheck).
    I don't think I am going to need it right away now. We were having finish problems, but we seem to have it dialed in... for now. I'll report back if we end up using it for something else.
    What's scary is they make a 10" version, still with a 3/4" shank!
  14. #11
    Jul 2006
    Hillsboro, New Hampshire
    9,932
    2309
    6924
    I gotta admit, the scenario of one's hand slipping off the little spindle lock lever on manual BP mills has been making me nervous for decades, so I either stop the spindle or use extra-extra caution when actuating it. But inside a VMC I'd be OK with that style flycutter, used wisely.
    But I'm not sure I buy the "rough-finish" aspect, as you're dealing with vibration/flex of each limb as it goes over the workpiece, and it could take some tuning of speeds to damp down resonance that might drive the cutter into the work in non-optimal waves.
  15. #12
    Feb 2013
    Idaho
    778
    181
    901
    Quote Originally Posted by Cole2534 View Post
    I believe he started with shift a full compliment of 10 and clocked out with 7.5 fingers. Final inventory from right to left: 0%, 25%, 50%, 75%, 100%. This was not his first machining related hospitalization, nor I doubt his last... kinda funny since he was the only person in 25 years that ever implied that I was a slow machinist. I suppose pausing before doing something stupid is a form of malingering
  16. #13
    May 2019
    Michigan
    2,065
    809
    1248
    Try this: https://www.iscar.com/eCatalog/item....FSTYP=I&isoD=1
    Not cheap but they do an awesome job. And you could do 150 IPM in aluminum.
    This explains how they work: https://www.iscar.com/eCatalog/MoreI...app=61&isoD=-1
  17. #14
    Mar 2006
    PHILIPPINES
    2,787
    784
    1159
    Are you looking for material removal or finish? I have been using the Cogsdill face burnishing tool for about a year now and it is absolutely awesome on finishes.
    Last edited by g-coder05; 08-04-2020 at 06:15 PM. Reason: My punctuation is poor...
  18. Likes TeachMePlease liked this post
  19. #15
    Mar 2007
    Milwaukee
    456
    350
    209
    I had a similar need for a 6” dia cutter for use in our VMC. I went the shop built route.
    We have an aluminum disk 7” round and 1.25” thick mounted securely to a Maritool face mill holder. The aluminum disk has a 3/8” square hole broached in it for a tool bit.
    I have been using a brazed on carbide tool that is meant for boring. McMaster Carr sells them. It’s the exact geometry I wanted in a fly cutter, positive rake and skewed.
    I’ve also seen the video of the square fly cutter blowing through the shop, scary! The round cutter reminds me of running a lathe. Great finishes and flat, I’d recommend this as a safe and affordable solution.
  20. #16
    Jul 2006
    9,932
    2309
    6924
    If'n yer going for finish, you might as well go diamond. Either PCD or natural. Natural gives an even better finish (no cobalt to stick to), but more spendy.
    As long as nobody trashes it or you don't hit an inclusion, natural diamond will give you near-permanent final finish and accuracy.
  21. #17
    Nov 2014
    Florida
    5,130
    2040
    2501
    Quote Originally Posted by g-coder05 View Post
    Surface finish. We have facemills, but boss don't like seeing lines if the part is wider than the cutter and have to make stepover(s). I think it is a bit overkill, but again, I have seen some of the pricing so I sort of understand the requirements, although I doubt the end user is as concerned as we are. I would prefer a brushed matte anodize as it 'hides' alot more imperfections.
    As to the flexbar, their recommendation is (extrapolated) about 500 rpm and 10ipm in aluminum for the 6" size.
    edit: Looking into those now, thanks for the heads up. Do you know if you use a smaller tool and make multiple passes in X/Y if it leaves any marks in between?
  22. #18
    Mar 2006
    PHILIPPINES
    2,787
    784
    1159
    We run 3" and it seems to be machine specific. If the tram is off then it does have a touch of a step but not as bad since the inserts are spring loaded. One thing I have noticed is if the part will go for a coating afterwards it doesn’t like to absorb. The burnish just kills the porosity.
  23. Likes Mike1974 liked this post
