Floppy Disk Emulator Help
Results 1 to 11 of 11
    Oct 2016
    AUSTRALIA
    13
    Default Floppy Disk Emulator Help
    Hi Guys,
    My customer has a Quick Tech CNC Machining Centre running Syntec 900ME, and we were unable to get the RS232 communication working, after trying everything we possibly could from the advice given in here. Thank you again.
    Anyway, we now have a floppy disk emulator that we have plugged in, instead of the actual floppy drive, so we can can load programs onto the machine via the emulators USB port.
    So far, we have been unable to make a successful transfer on either direction.
    I’m wondering if we are doing it wrong. Does anyone know the correct procedure to get this thing working ? So far I’ve plugged in the USB, and tried to send a program to it, but to no avail.
    Does anyone know the correct procedure ?
    It looks like this one. Cheers.
    floppy disk emulator - Google Search
    Jul 2006
    Hillsboro, New Hampshire
    10,132
    2368
    7079
    If you're using a true emulator, it needs a thumb drive that's been "modded" to look like a 1.44Mb floppy disk. This utility will take a regular thumb/flash USB drive and reformat it to suit.
    GOTEK Floppy Emulator - philscomputerlab.com
    Let us know if that works for you. Be careful about deleting programs from the drive, I've found I have to rerun the utility again to properly format the drive once I've removed files from it.
    You also want to get used to formally "ejecting" the drive from the Windows environment, as just pulling the drive may corrupt it. Not an issue on the machine side, just the Windows side.
    Jan 2014
    Washington
    5,334
    964
    2953
    Have you tried contacting Syntec about the RS232?
    syntecamerica.com
    I set up RS232 on a Syntec 900 on a lathe about 12 years ago and don't recall there being anything too difficult about it. I don't have access to that machine or any info about it any more so can't offer anything more.
    May 2002
    South Central PA
    14,140
    2566
    3850
    I know less than nothing about your machine. But I HAVE heard that sometimes you have to format the USB stick in the emulator in order for it to work correctly.
    Jul 2006
    10,132
    2368
    7079
    Quote Originally Posted by Mud View Post
    Huh - I've always used the utility I mentioned in #2, I'm not sure how you'd do it in the emulator itself unless it had a routine built in for it. Maybe some do, but the emulator drives I've bought don't (I think).
    Sep 2009
    tonawanda new york
    264
    53
    94
    Call Shop Floor Automation.I have an emulator from them. When I set it up I had to set dip switches on the emulator to be compatable with my machine. Also the thumb drive had to be 2 gigs or less in size.
    Aug 2013
    Chicago, IL
    1,073
    776
    419
    This ^^^^^^^^^^^^^^^^^ Format the USB drive to make it look like a floppy. In fact, when I plug the USB into the computer it lists it as a “floppy drive.”
    Dec 2015
    Connecticut
    1,209
    29
    406
    Dumb question, I only need one floppy emulator for the machine right? I can use the software on the pc to format the USB drive??(no emulator on pc)
    Oct 2016
    AUSTRALIA
    13
    Man, this worked a treat. Once I downloaded this software and watch Phil's video, it all worked. And made sense. Thanks for your help.
    Thanks everyone that commented. Much appreciated.
  10. Likes Milland liked this post
  11. #10
    Oct 2016
    AUSTRALIA
    13
    Quote Originally Posted by ripperj View Post
    Yes correct. Just follow Millands link above and watch the video so you understand how to save files to the USB etc..
  12. #11
    Jul 2006
    10,132
    2368
    7079
    Right, just use the software utility on the PC to format a USB to "lobotomize" it into a 1.44Mb format. Really old machines might need the .72Mb formatting, but I've not seen that myself.
