david n
- Apr 13, 2007
- Pillager, MN
Coolant kept foamin' over......... Skimmed it(extra). Pumped it out into a 55 gllon drum and let it sit over the weekend and skimmed it aggin'.............Added a bit of the anti-foam schtuff..........Still made suds.............So I swapped it out...................But the coolant wasn't all that old? Pumped out the old stuff, cleaned the tank, topped 'er off with the new stuff. Turn my back on it and it's foamin' aggin'..................but.......the pump sounds "odd"? Like she's suckin air? What's goin on? No frills pump other other than it's an upgrade from the standard PSI pump. This one is 145PSI or so. Pull er apart? Never pulled one of these apart? Anything to look for that might be the culprit?
