Friction comp for Daewoo cnc mill fanuc controller
Results 1 to 6 of 6
    Dec 2020
    Maryland
    240
    140
    48
    Default Friction comp for Daewoo cnc mill fanuc controller
    Hi all,
    I was wondering if any of you know how to apply friction comp for a Daewoo 3016 3 axis mill? I never knew such a thing existed until a couple weeks ago. A guy I know said he adjusts friction comp on his Haas depending on how much weight is on the table (ie. 1 vise, 2 vises, 3 vises, a big heavy part, etc). We usually just keep 1 kurt vise on the table.
    Does anybody else here use this parameter adjustment? Also, what is the parameter adjustment for this on a Fanuc Oi-MB controller?
    Chris
    Dec 2020
    Maryland
    240
    140
    48
    Bump
    Is anybody here familiar with this parameter?
    Jan 2019
    Missouri
    403
    107
    102
    This is from the manual for newer controls 31i and 0iMD. I dont think you meed to worry about this on a small LM guide machine. Are you having an actual issue?
    What is on a Haas control is not the same as on another control. Haas may hook that value into the gain or who knows what.
    5.SERVO FUNCTION DETAILS
    B-65270EN/08
    - 246 -
    5.5.6
    Static Friction Compensation Function
    (1) Overview
    When a machine, originally in the stop state, is activated, the increase in speed may be delayed by there
    being a large amount of static friction. The backlash acceleration function (see Subsection 5.5.4 and
    Subsection 5.5.5) performs compensation when the motor rotation is reversed. This function adds
    compensation data to a velocity command when the motor, originally in the stop state, is requested to
    rotate in the same direction, thus reducing the activation delay.
  4. Likes cgrim3 liked this post
    Dec 2020
    Maryland
    240
    140
    48
    No not having an issue. Just something I discovered and wanted to learn and possibly fiddle around with this parameter on the machine. I appreciate your response.
    It seems like this isn't a very well known topic among the machining community but I may be wrong
    The machine we have is box way
    Jan 2014
    Washington
    5,609
    1008
    3156
    Quote Originally Posted by cgrim3 View Post
    Unless you have a flimsy machine or are doing super nice mold cavity type work, you don’t need to eff with it.
  7. Likes cgrim3 liked this post
  8. #6
    Jun 2011
    New Jersey
    1,498
    798
    651
    Agreed. I'd leave this alone. I can see bad things happening. Most of the time stuff like this is set and then left.
    I'd be more interested in look ahead, feed rates, etc.
  9. Likes cgrim3 liked this post
