Fuji DC Spindle Drive Repair
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Mar 2018
    13
    Default Fuji DC Spindle Drive Repair
    Hello all,
    I have a Fuji FSD-37DN23 DC Drive that is in need of repair. It is out of a 1984 Ikegai VT1100. The drive was repaired a few months back and worked fine for a while then recently went down again. It was sent back to the repair facility under warranty but unfortunately they have informed me that it is beyond repair this time.
    Ikegai tells me that the drive has been discontinued without replacement.
    Does anyone happen to know of a repair source that can possibly resurrect this drive or where I may be able to locate a replacement?
    Dave
    Feb 2018
    82
    I had a 80's Mori with a 25hp DC spindle drive that I had spent about 12G
    trying to keep running over about a 3 year period. Had it converted to an AC VFD ,New AC motor and a Teco Westinghouse Controller for about the price of repairing the DC
    spindle drive. It's been running without a glitch for about 30 years now.
  3. Likes Garwood liked this post
    Jan 2014
    Washington
    4,672
    846
    2538
    mc3608 has your answer. Switch the motor to an AC unit and drive it with a VFD. Any reasonably smart tech will be able do the interface.
    Mar 2018
    13
    Thanks for the input.
    Converting to VFD is an option that I may be forced to use.
    I was hoping to stay with the DC as I just had the 37 KW motor rebuilt including the field coil rewind so I have a good chunk of change into it and only about 20 hours of run time on it.
    mc3608 did you up the HP of the AC replacement motor? Do you have any issues running at low RPM?
    Dave
    Feb 2018
    82
    Quote Originally Posted by dave morgan View Post
    Dave
    I replaced the 25hp DC motor with a 25hp Ac. It runs thru a geared spindle and have never
    had an issue with power at low or any rpm, also the CSS still works.
    It worked so well that I had 2 more of the 80's machines converted and have never had a Glitch.
    Oct 2009
    Oregon
    4,320
    4638
    2225
    I would go AC, but if you can't or won't then look at what Bardac offers. They can configure a new DC drive to work with your old control. I would still go AC though.
    Jan 2014
    Washington
    4,672
    846
    2538
    .....I was hoping to stay with the DC as I just had the 37 KW motor rebuilt including the field coil rewind so I have a good chunk of change into it and only about 20 hours of run time on it.....
    Maybe need to talk to some place like this then. I don't have any experience with them. I have heard of the brand is all.
    Polyspede Electronics Corporation | Variable Speed Drives and Inverters for Automation
  9. #8
    Jan 2019
    Arizona
    672
    58
    232
    drives warehouse in texas
    talk to darrin
    888-476-5944
  10. #9
    Sep 2006
    SW Wisconsin
    518
    23
    132
    DON'T!! I tried one on a 10HP Dc spindle. Miserable pig to set up and never got it right, wouldn't set the correct speed as a replacement for Fanuc.
    Went with the above mentioned AC motor and a VFD. If you can get the right motor try to pulley the speed down and increase the top end Hz.
    That will give you a better low end for torque.
    Ed.
  11. #10
    Mar 2018
    13
    Thanks for the input and possible replacement sources.
    The DC motor on this VTL has two speeds 1150 and 3500 RPM that can be changed via M38/M39 or a toggle and pushbutton on the control.
    Would I be able to retain this feature with the AC conversion?
    atex57, was that a Digital or Analog drive that gave you problems?
    Dave
  12. #11
    Jan 2014
    Washington
    4,672
    846
    2538
    .......The DC motor on this VTL has two speeds 1150 and 3500 RPM that can be changed via M38/M39 or a toggle and pushbutton on the control.
    Would I be able to retain this feature with the AC conversion......
    That sounds like shifting ranges in a 2 speed gearbox to me. If it is, then changing to an AC setup would not change it.
  13. #12
    Mar 2018
    13
    Vancbiker this machine also has a two speed gearbox. High and Low Ranges of the gear box are selected manually with a lever.
    With the motor in low I can get a max of 90 or 280 rpm respectively at chuck
    With the motor in high I can get 270 with the gearbox in low and possibly up to 800 in high but I never had it over 400 rpm.
    Dave
  14. #13
    Jan 2014
    Washington
    4,672
    846
    2538
    Then the M code speed changes must be switching the field windings from a 2 pole (high speed) configuration to a 4 pole (low speed) configuration. I have never worked on a motor set up like that.
    In any case you would probably not need to do that with an AC conversion. You could, but it would require some additional interfacing. It probably would also mean a "standard" 3 phase motor would not be useable.
  15. #14
    Mar 2011
    MASS
    950
    405
    297
    Hello all,
    Dave
    I just parted out two ikegai with Fanuc 6T and have two spindle drives in front of me.
    give me a part # and we can work out a deal
  16. #15
    Mar 2018
    13
    Solidworkscadman,
    I don’t have an Ikegia part number only have the Fuji numbers
    on the drive FSD-37DN23. My control is a 10T
    Dave
  17. #16
    Mar 2011
    MASS
    950
    405
    297
    this came off a 10t
    A06b 6044 h108
  18. #17
    Jan 2014
    Washington
    4,672
    846
    2538
    Quote Originally Posted by solidworkscadman View Post
    this came off a 10t
    A06b 6044 h108
    That's an AC drive. Not compatible with the OP's machine.
  19. #18
    Mar 2011
    MASS
    950
    405
    297
    i had a FX20n that had a DC servo drive
    in total we scrapped 4 ikegai's
    sorry
  20. #19
    Mar 2018
    13
    Solidworkscadman,
    Thanks for checking what you have.
    Vancbiker,
    The the motor is a Separately Excited DC Motor. I am not really sure how the high and low speed ranges are controlled.
    Dave
  21. #20
    Jan 2014
    Washington
    4,672
    846
    2538
    .......The the motor is a Separately Excited DC Motor. I am not really sure how the high and low speed ranges are controlled......
    I think that every DC spindle motor I have seen has been a separately excited type. Machine builders used that type to get a wider speed adjustability range than can be obtained by a series wound or shunt wound type.
    If you have the electrical schematics covering the spindle motor connections it would be nice if you could post a large, clear scan of them. I'd be interested to see what they are doing with the M38/M39.
