G0G91G28Z0. cancelling G43 offset
Results 1 to 19 of 19
    Jul 2021
    Michigan
    Default G0G91G28Z0. cancelling G43 offset
    Hello,
    We have a Fanuc Oi-MF control on an Awea AV1000 mill.
    If G43 H4 is active for the tool length offset and I do a G0G91G28Z0 or if I do G0G91G30Z0 the H4 value is cancelled.
    If you look at the position check screen where you can see all active G-codes and H & T values it still shows the H4 as being active but it is definitely not active anymore after the machine returns to zero return or 2nd zero return.
    I am fairly certain this is a parameter issue. If someone can tell me the parameter to change it would be greatly appreciated.
    Thanks!
    Aug 2002
    West Unity, Ohio
    27,661
    8002
    9743
    This app is only barely in my wheelhouse, but when you punch in G28, that runs off of "Machine Zero" or whatnot.
    It has to dump any tool, fixture, or G10 offsets to make this move.
    Now - you say that it is still showing active in your list, and if so - then it only disregarded it for the G28 move, but maybe it is still active should you want to continue for some reason from a G28 position - although that seems an odd application.
    What is it that you are expecting - or desire it to doo differently?
    Think Snow Eh!
    Ox
    Jun 2015
    Minnesota
    766
    12
    274
    Not sure why you're running home and then back again with the same tool, unless there's some in program clearance you're after. Your problem might be that I don't see a G90 mentioned after all your G91 activity. Perhaps your machine is returning to work under an Incremental mindset.
    Another route is use G53 instead of G28. Simpler way to obtain the same movements, and it won't take you out of Absolute Mode.
    Sep 2010
    Victoria Australia
    4,170
    1778
    Quote Originally Posted by 13engines View Post
    The Tool Length Offset is also cancelled by G53.
    @markgerke
    Check carefully that the Tool Length Offset is still active with the next Z Move in Absolute Mode, as it should be restored.
    Regards,
    Bill
    Sep 2015
    Ohio
    1,833
    1202
    1975
    Check to see if G49 is active. That's what cancels tool offset.
    The H value would be the last H value read.
    If you called G43 with no H, it would use the active H (in your case H4)
    Oct 2007
    SPAIN
    5,126
    936
    537
    Another curve to G53...if you're just sending the Z home out the way, you could just turn your rotary knob to the "home/zero return" position and hit the Z home button.
    Less typing...
    Sep 2010
    Victoria Australia
    4,170
    1778
    Quote Originally Posted by Booze Daily View Post
    Hello BD,
    Not necessarily, it depends on the setting of parameter bit 5001.2. If set to "0", that's correct. If set to "1", then Offset H00 will be made active, which is the same as cancelling the Offset as H00 has the value Zero and can't be set otherwise.
    Regards,
    Bill
    Sep 2009
    NEW ZEALAND
    128
    46
    So, I've always wondered why Fanuc(and simaler) use separate diameter/length offsets.
    Is there a practical reason or is is some legacy thing from older controls.
    I'm sure there's a good reason I just can't think of one.
    (So I'm coming from Heidenhain where the tool call contains all the info and tool lengths aren't cancelled (well I suppose they are temporarily)
    by moving in machine coords etc)
    Oct 2007
    SPAIN
    5,126
    936
    537
    (New) Siemens is the same as Heidi - you just call your tool and the control automatically assigns your H+D because why would you use another number.
    Well, if you're interpolating a couple of tight features with the same tool number...you can then control exactly what you want for each feature with a separate D#
    (obviously you can do it other ways but this is an option...)
    Aug 2002
    West Unity, Ohio
    27,661
    8002
    9743
    Quote Originally Posted by srp61 View Post
    In case you want slightly different offsets for the same tool.
    ex:
    Maybe doo to tool pressure, you may want a slightly smaller D on a longer cut surface than on a shorter wall surface?
    Not sumpthing that comes up all that often, but .....
    Think Snow Eh!
    Ox
  11. Likes mhajicek liked this post
  12. #11
    Nov 2005
    Santa Barbara
    316
    101
    I sometimes use different D's when I have to turn big and small tight diameters with the same tool. If you need a 16" diameter on the back, and a 1/4" on the front, a slight offset in Y can easily cost you a few tenths. Separate D's let you tune them both in, without shimming up the tool.
    On mills, I have engineers who like giving one sided tolerances. Sometimes I'll miss it when I'm programming. At the machine, it's easier to add a new D, than to fingercam a bigger/smaller tool path for that one sloppy callout.
  13. #12
    May 2017
    Minnesota
    2,013
    2744
    1407
    Exactly. I've run several jobs lately in which a given tool will have two or three different D offsets for dialing in different features.
  14. #13
    Oct 2007
    SPAIN
    5,126
    936
    537
    Another way to adjust the tool (keeping the same offset number) for tight features, that i've just come across and used this week, is by using the attached.
  15. #14
    Jan 2014
    Washington
    5,701
    1009
    3220
    Quote Originally Posted by barbter View Post
    That method can be ok, but without some care in programming can result in trouble should the program be aborted mid operation. Using alternate D addresses has fewer pitfalls.
  16. #15
    Oct 2007
    SPAIN
    5,126
    936
    537
    The variable I used was the H wear. The part had a tight limit floor depth (+/- 10 microns = 0.0004") and a following shallow angle scanned feature.
    So after the floor and the Z retract, before the start of the scanned feature, I stored the existing H wear offset with a (#150) variable,
    then had the following line with #10004 = 0 (ADJUST Z HEIGHT FOR CHAMFER).
    This tool being T4 (a bull nose - hence me wanting the ability to adjust the Z incase the rad grinding isn't cock-on).
    Then at the end of the feature (T4 toolpaths) on the last line before toolchange, I had this
    #10004 = #150 ( DO NOT CHANGE. THIS LINE POPULATES WEAR TABLE WITH INITIAL SET VALUE FOR THIS TOOL )
    So at the end of the tool, the existing tool wear value is automatically re-entered into the tool table. So next part, the previous H value (whatever that is) is back as was.
  17. #16
    Jan 2014
    Washington
    5,701
    1009
    3220
    ^ this is what I meant about careful programming. 👍
  18. #17
    Oct 2007
    SPAIN
    5,126
    936
    537
    ^ this is what I meant about careful programming. ��
    Buuuuttt... i was just thinking....If reset got hit after the start of the scanning/chamfer (ie after the second wear H is called) to re-run the tool at the start, then the 2nd wear value will be what's in the tool table...
    Hmmmmm......
  19. #18
    Jan 2014
    Washington
    5,701
    1009
    3220
    You need to set the appropriate wear value at the beginning of each op.
  20. Likes barbter liked this post
  21. #19
    Jun 2011
    New Jersey
    1,681
    912
    740
    To cancel a G43 height offset, you would need a G49.
    Depending on how the machine's parameters are set, BE CAREFUL, I've seen machines "take off" when the offset is cancelled.
    Usually, when I'm done with a tool and send the spindle home with a G28G91Z0;, my startup line after the M06 looks something like this:
    N20 G0 G40 G49 G54 G80 G90 etc
    Now I know that all old offsets and comp are cancelled, cycles are cancelled, etc.
