ljeremy578
- Aug 6, 2018
I am using a Doosan Lynx 2100LSY with a Fanuc controller and noticed there was a G350 in the codes list. Who uses this? Is it something I should be using? Thanks for the input.
Google says it's cutoff confirmation on your machine.
It checks to make sure the part is cut off ??
It's not enough to know the tool is at X0....???
What if the part off tool breaks? Be nice to verify separation before retracting the sub spindle.
How does it work then? Gentle retract with the subspindle to see if it wants to come along??
Can only speak for myself, but that's how I do it....
This is a possible solution for machines that did not come with a factory cutoff check function. It still requires some method of setting the torque limit condition or value. Do you have an M-code for that or some other method?
No M code on the machine I use this on, discussed it a few times on here before. I posted a rough draft of my method in this thread - I've refined it since then, rolled it into a macro and assigned a g code etc.
Can only speak for myself, but that's how I do it - retract with torque skip, then check the position to see if it got to where it was going.
Machines have a sensor built in next to the cutoff tool.
M51 rapids to clearance plane, positions the sensor, and feeds to X0 and looks for the sensor to trip. Easy peasy.
Good solution. I don't recall that thread, but no surprise as I sometimes forget what was for dinner last night!
Not familiar with this one, but some machines incorporate a "whisker" probe to make sure the area is clear.
Never used one tho.
Think Snow Eh!
Ox
Never used one tho.
Think Snow Eh!
Ox
Notice
