claya
Cast Iron
- Aug 6, 2006
- california
I cannot get this G41 to work with any comp of more than 0.0025". The G41 line and subsequent lines are generated by a thread milling app (SCT.) Adding an extra move before the G41 fails. Climb milling.
This is for a 0-80 thread, so not a lot of room to work with the tool in the bottom of the hole. I think the problem is the G03 radius is too small for anything more than 0.0025" comp. How do I get around this?
If I switch to conventional milling will the G42 work with larger than 0.0025"?
I am not sure the tiny 0-80 thread-mill can handle conventional milling. Material is Inconel 718.
Or IF I change the G41 to G42 and use a - comp value will it work?
Suggestions?
(3 PASS)
/N10 G00 X0. Y0.39 M8
/N12 G43 Z0.1 H3
N14 G90 G00 Z-0.145 F5.0
N16 G91 G41 G01 X0.0014 Y0.0006 F0.42 D103
N18 G03 X-0.0021 Y0.0041 Z0.0031 I-0.0028 J0.0011
Suggestions?
(3 PASS)
/N12 G43 Z0.1 H3
