Hi everyone!
I have been involved in CNC using and machining for a long time.
I also have a fairly modern lathe at home, which I deal with as a private business plus.
I recently got ordering a special piece that I would need to produce in larger quantities. However, it has an R5 radius on it and I was thinking of using the G41 function on the machine. The machine is controlled by FANUC.
Unfortunately, the radius size is good until 40 pieces and we are in tolerance, but then the radius size goes away and we are out of tolerance. I saw there is a radius correction option in offset, but it didn't work that much either. My question would be if anyone has any idea what the trouble might be or how their experience could be best used.
My other question would be that I have read the manual and can use tool breakage monitoring in it. Unfortunately, nowhere did I find a description of how it could and should be used, run on the machine (FANUC control).
Thanks in advance for your help!
