G43.4 on NTX2500 CELOS
gregormarwick
Feb 7, 2007
Aberdeen, UK
We have a new NTX2500 with Celos/Fanuc 31iB5, I am programming with Featurecam and we have a post supplied by Autodesk.
I am going through it proving the post out, and so far it seems solid, just a few very minor tweaks.
Today I tried a simple 5 axis simultaneous path, machining a tapered hole with an endmill with a swarf toolpath. Problem I'm having is that with G43.4 enabled, it seems to move correctly in X-Z-B, but not in Y-C. Visually, it looks like C is moving about the right amount to follow the toolpath, but Y distance is somewhere around the actual coordinates in the program, i.e very little Y axis movement, and not following C properly.
Full code is a lot of lines, I trimmed a whole lot of it out of the middle to post here.
Anyone know what might be going on?
O0001(TEST PART 2)
( MORI SEIKI NTX )
( 03/06/2020 - 18:53:18 )
N1 ( WNT 54 612 164-ROTARY )
( MAIN SPINDLE, Z-AXIS ROTARY TOOL )
( FINISH1 SWARF SRF_MILL1_1 )
G17 G21 G40 G54 G80 G98
M69
G0 T17 ( WNT 54 612 164-ROTARY )
G361 B-90.0 D0.
G43 H1
M594
M369
M45
G28 H0.
M303
G97 S6000 M13
G0 C-1.371
G49
G43.4 D9
X340.819 Y-1.993 Z59.531 B-49.98 M8
X182.031 Y-0.093 Z-35.048
G1 X178.174 Y-0.047 Z-37.345 F625.
Y-0.049 B-49.977 C-1.424 F1250.
Y-0.051 B-49.974 C-1.478
Y-0.053 B-49.971 C-1.532
Y-0.054 B-49.967 C-1.586
Y-0.056 Z-37.346 B-49.964 C-1.64
Y-0.058 B-49.961 C-1.693
Y-0.06 B-49.958 C-1.747
Y-0.062 B-49.955 C-1.801
Y-0.064 B-49.951 C-1.855
Y-0.066 B-49.948 C-1.909
Y-0.067 B-49.945 C-1.962
X178.175 Y-0.069 B-49.942 C-2.016
Y-0.071 B-49.939 C-2.07
Y-0.073 Z-37.347 B-49.935 C-2.124
Y-0.075 B-49.932 C-2.178
Y-0.077 B-49.929 C-2.231
Y-0.079 B-49.926 C-2.285
Y-0.08 B-49.923 C-2.339
Y-0.082 B-49.919 C-2.393
Y-0.084 B-49.916 C-2.447
Y-0.086 B-49.913 C-2.5
Y-0.088 Z-37.348 B-49.91 C-2.554
Y-0.09 B-49.907 C-2.608
...big chunk of code trimmed out...
X178.174 Y0.07 B-49.94 C2.022
Y0.068 B-49.941 C1.968
Y0.066 B-49.943 C1.914
Y0.064 B-49.944 C1.86
Y0.062 B-49.946 C1.806
Y0.06 B-49.947 C1.752
Y0.058 B-49.949 C1.698
Y0.057 B-49.95 C1.644
Y0.055 B-49.952 C1.59
Y0.053 B-49.953 C1.536
Y0.051 B-49.955 C1.482
Y0.049 B-49.957 C1.428
Y0.047 B-49.958 C1.374
Y0.045 B-49.96 C1.32
Y0.043 B-49.961 C1.266
Y0.042 B-49.963 C1.212
Y0.04 B-49.964 C1.158
Y0.038 B-49.966 C1.103
Y0.036 Z-37.345 B-49.967 C1.049
Y0.034 B-49.969 C0.995
Y0.032 B-49.97 C0.941
Y0.03 B-49.972 C0.887
Y0.029 B-49.973 C0.833
Y0.027 B-49.975 C0.779
Y0.025 B-49.976 C0.725
X178.173 Y0.023 B-49.978 C0.671
Y0.021 B-49.979 C0.617
Y0.019 B-49.981 C0.563
Y0.017 B-49.982 C0.509
Y0.016 B-49.984 C0.455
Y0.014 B-49.985 C0.401
Y0.012 B-49.987 C0.347
Y0.01 B-49.989 C0.293
Y0.008 B-49.99 C0.239
Y0.006 B-49.992 C0.185
Y0.004 B-49.993 C0.131
Y0.003 B-49.995 C0.076
Y0.001 Z-37.344 B-49.996 C0.022
Y-0.001 B-49.998 C-0.032
Y-0.003 B-49.999 C-0.086
Y-0.005 B-49.998 C-0.139
Y-0.007 C-0.193
Y-0.008 B-49.997 C-0.246
Y-0.01 B-49.996 C-0.3
Y-0.012 B-49.995 C-0.353
Y-0.014 Z-37.345 B-49.994 C-0.407
Y-0.016 C-0.46
Y-0.018 B-49.993 C-0.514
Y-0.019 B-49.992 C-0.568
Y-0.021 B-49.991 C-0.621
Y-0.023 C-0.675
Y-0.025 B-49.99 C-0.728
Y-0.027 B-49.989 C-0.782
Y-0.029 B-49.988 C-0.835
Y-0.031 B-49.987 C-0.889
Y-0.032 C-0.942
Y-0.034 B-49.986 C-0.996
Y-0.036 B-49.985 C-1.049
Y-0.038 B-49.984 C-1.103
Y-0.04 B-49.983 C-1.156
Y-0.042 C-1.21
Y-0.043 B-49.982 C-1.263
X178.174 Y-0.045 B-49.981 C-1.317
Y-0.047 B-49.98 C-1.371
G0
X252.993 Y-0.942 Z7.22
Z28.0
G49
M595
M5
M46
M9
G28 U0. V0.
G28 W0.
G0 B-90.
M30
In case anyone else ends up here with the same question, the machine was set to "Workpiece Coordinate System", when it was required to be in "Table Coordinate System".
Parameter 19696.5 1 > 0
