gcodeguy
Hot Rolled
- Jun 17, 2007
- Easton, PA
First this control doesn't allow a Z(W) on the first block for Type 2 (I believe) cycle. Not a biggie. Can't use brackets inside the G71, so I thought I would get smart and set my program up a bit differently than usual. Start position may look a little off because it is using a lead angle turning tool.
The problem is...as written...it turns .4665 (.4765 actual, natch) diameter for the full length UNTIL the last pass. On the last pass it turns all the diameters as it should. Why? I'm converting to my usual way of running so the lathe won't be sitting idle, but I'd like to know if there is a way of programming as in this example. Thanks.
X1.Z.5
G50S3000
G96S650
Z-.05
G1Z-.08F.012
#1=.2995+#510
#2=.4655+#511
#3=.513+#512
#4=.513+#513
#5=.5565+#514
#6=.7635+#515
G71U.053R.01
G71P11Q12U.01W.005F.008
N11G1X#1
U.1181Z-.1391
U.0479Z-.1806 (X.4655)
X#2Z-.5495 (X.4655)
X#3W-.0238 (X.513)
X#4Z-.965 (X.513)
X#5W-.0233 (X.5565)
Z-1.4443
X#6W-.0277
U.0385W-.0333 (X.802)
Z-1.713
N12X1.W-.03
X1.Z.5
G50S3000
G96S650
Z-.05
G1Z-.08F.012
#1=.2995+#510
#2=.4655+#511
#3=.513+#512
#4=.513+#513
#5=.5565+#514
#6=.7635+#515
G71U.053R.01
N11G1X#1
U.1181Z-.1391
X#2Z-.5495 (X.4655)
X#3W-.0238 (X.513)
X#4Z-.965 (X.513)
X#5W-.0233 (X.5565)
Z-1.4443
X#6W-.0277
Z-1.713
N12X1.W-.03
