G72 Cuts more than programed
Results 1 to 7 of 7
    Aug 2018
    Oklahoma
    Default G72 Cuts more than programed
    Hey I can't find any one with this problem. I was working on a part and using my Doosan Lynx 220 Turning center. Graphed before running the part. The machine wants to cut .030 more than I programmed.
    M00;
    T101;
    G50 S3000;
    G96 S500 M03;
    G00 G54 G42 X2.3 Z0.25;
    M08;
    G72 W0.05 R0.01 (0.05 IS TO SEED UP SIM);
    G72 P05 Q09 U0.0 W0.0 F0.002;
    N05 G01 X2.3 Z0.0;
    Z0.0;
    N09 X-0.033;
    The last cut is Z-0.030 when it should be Z0.0
    Many thanks in advanc.
    Feb 2017
    69
    5
    27
    Probably your cutter comp G42. Try it without.
    When i run a G72 it would look like this:
    T101;
    G50 S3000;
    G96 S500 M03;
    G00 G54 G40 X2.3 Z0.25;
    M08;
    G72 P05 Q09 F0.002;
    N05 G0 Z0.0;
    N09 G1 X-0.033;
    Dec 2014
    CANADA
    British Columbia
    1,245
    352
    577
    CAM or fingerCAM? Do you have the TNR, quadrant etc defined properly for TNR comp?
    Jun 2012
    Michigan
    4,458
    4048
    2635
    I'm pretty sure the G42 needs to be in the G72 cycle on the N05 line.
    Even though the G72 doesn't read the G42 INSIDE the P and Q lines, the G70 will. And since you have it turned on before the cycle, that might be where your .03 is coming from... assuming you have .03 in your comp.
    Mar 2003
    Upstate New York USA
    281
    43
    why bother using TNRC on a straight line face cut move anyway?
    Aug 2018
    Oklahoma
    Hazzert, I used FingerCAM and I have tip 3 with a 0.015 R in tool geometry
    Tom the G72 was an after thought. I am still learning G-Code at tech and thought a G71 could handle the whole thing.
    I'll try turning off TNRC.
    Sep 2010
    Victoria Australia
    3,611
    1416
    Quote Originally Posted by KevinEwards View Post
    M00;
    T101;
    G50 S3000;
    G96 S500 M03;
    M08;
    N05 G01 X2.3 Z0.0;
    Z0.0;
    N09 X-0.033;
    Hello Kevin,
    1. As Tom points out, there is no need whatsoever in using TNR Comp on a Face Cut that is perpendicular to the Z axis.
    2. The tool is to the Left of the Tool Path in the direction it travels, accordingly, G41 should be used, not G42; that is the reason for your over-cut.
    Regards,
    Bill
  8. Likes rainman liked this post
