G76 on Fanuc 32i-Model A, Spindle Speed Override, Lathe
Results 1 to 8 of 8
    Mar 2015
    Michigan
    295
    46
    77
    Default G76 on Fanuc 32i-Model A, Spindle Speed Override, Lathe
    On our Doosan lathe with Fanuc 32i we would like to be able to override the commanded spindle speed using the knob on the controller during a canned cycle, G76, as that's what is typical with the rest of the lathes in our shop. Is there any way to make this happen?
    Jul 2013
    Indiana
    3,006
    4409
    1510
    Not that I know of? The macro program that runs the G76 cycle disables the spindle and feed overrides. I believe G31 G32 G91 are the same. The other machines are Fanuc controlled?
    Brent
    Jul 2013
    Indiana
    3,006
    4409
    1510
    I bet this feature is an extra paid option? Not a standard feature for a Doosan machine.
    Brent
    Mar 2015
    Michigan
    295
    46
    77
    Gotcha.
    In our shop we've got (mostly) older Fanuc controllers...4T, 5T. It works with those.
    Jan 2014
    Washington
    3,399
    654
    1746
    Disabling the spindle override is determined by the machine builder, not Fanuc on newer controls.
    Adjusting the spindle speed during a threading cycle on older controls usually results in a slightly imperfect thread form due to synchronization errors between the Z servo and the spindle drive. The Z servo velocity is only updated once per spindle revolution. The amount of error depends on how quickly and how far the override is turned and the spindle's response speed to override input. Generally it is advised to not adjust the override during threading operations.
    Mar 2015
    Michigan
    295
    46
    77
    Interesting.
    Thanks guys.
    Sep 2010
    india
    1,102
    65
    189
    Yes. That is correct. A changed spindle speed might result in a shifted helix, hence the same rpm must be used, even if it is possible to change it. It is because of this reason that CSS is not used in threading.
    Sep 2008
    Florida
    351
    29
    91
    I've run Okumas in the past that would "accept" CSS for threading, but what a mess it made of threads when it was used!
