Meldas 600 m32 citizen y02 alarm system 0051 0001
Driss
Dec 10, 2019
hello friends i have a problem with mitsubishi meldas 600 when i turn on the machine it works after some time their stopping with an alarm y2 alarm system 0051 0001 help me
Communication error between CNC and a drive. Any alarms showing on the drives?
Check for good clean cable connections on the data cable from the CNC to the drives. It's a daisy chain cable.
Check for good shield ground on the cables.
Check for good machine ground.
I'm fine I hope you are fine yes I checked and I found that the earth and male serene and I noticed another problem that the Hr561 expansion card is defective I changed it and everything is fine alright great thank you very much
