Hi all,
We have never rigid tapped before on our cnc lathe but a job has come up where we need to rigid tap. The controller is meldas 500 on a daewoo puma 200 from 1997. I am form tapping a 3/8-24 thread. I have the following code:
N900 T0909 G54;
G00 X0. Z.2;
G84 S500 M3 Z-1.2 F.0416667 R.1 P0., R1
G00 G40 T0900 X10. Z6.
M1
I have the RPM info in the G84 line. I originally had it above the G84 line but the controller spit out a P181 No S-CMD (Tap) error. This is saying that the RPM info should be in the G84 line instead of above it.
Before trying to rigid tap, I did put ",R1" in the G84 line to call up parameter 29 which is auto sync tap.
When I start the program, the tool rapids to .2" in front of the part like it is supposed to. Then, the spindle tries to turn but it doesn't. The spindle does not turn and the tool doesn't move. I assume this is because in rigid tapping, the Z movement of the tool is linked to the rotation of the spindle, so since the spindle isn't moving, the tool won't move either. However, the control does not throw an alarm. What should I do to fix this?
Note: I can get the unsynchronized tapping to work fine (by taking out the R1) but the rigid tapping doesn't seem to work.
Any help would be appreciated.
Chris
N900 T0909 G54;
G00 X0. Z.2;
M1
Chris
