bdrmachine
- Mar 21, 2017
I have a 1000 part job that requires 4 .2515" reamed holes. The hole tolerance is +/- .0005". This is the 2nd batch of these parts with more to come. I would like to tweak the program too speed things up a bit. I'm using all carbide tools, drilling 15/64 at 2050 rpm and 6.25 ipm thru a 3/8 1018 steel part. Than reaming at 950rpm 5.5ipm using a G98 G85 canned cycle. I don't like the fact that g85 retracts at the same speed rate. Would I have any problem coding each hole separately with a F200 retract speed? Any suggestion on my speed and feeds?
Much
Much
