Machine is a Tsugami TM8AII mill/ turn with B head..no turret
Control Tsugami Fanuc LH2 (fanuc 16i ?)
The G87 works fine on the 1st hole of the sequence , pecks as it should using the Q
address, when repositioning in Y or indexing C the next hole will plunge straight to depth
at feed and retract all holes after will do the same.
