G96 vs G97 Part Off
I never use constant surface feed on cut-off, but I never barfeed anything bigger than 1.375". In fact I usually do the opposite and slow the rpms the last .100 depth so the part drops in the part catcher and doesn't go flying.
If you're parting off anything that has some size to it, you should be using constant surface speed.
On small 1" dia parts it wouldn't matter too much, but larger dia parts it makes a world of diff.
Do you turn parts in only G97 using the same RPM on a 4" dia part that you do on a 1" dia part?
Not if you're cutting steels.
Before this thread continues any more please be sure to set your max rpm during constant surface speed ( most of the time G50) to a safe any acceptable level. Nothing scarier than a 1-1/4 hex bar x 12 feet long whipping at 5000 rpms.
For 1.25 dia and smaller I just use normal G97. But larger stuff I use G96. But I make sure G50 is called up in several locations just to be safe.
