Hi all.
I am attempting to pull some 7/16" 303, hex, while I am in M110, to align the hex flats with the flats on my bar puller.
(picture attached)
https://bettersolutionsinc.com/Content/Images/royal_compact_cnc_bar_puller.jpg
I set C zero after indicating the flats on the hex parallel with x axis.
I commanded a C0 and then G1 (via G94) to feed in X until the hex is gripped.
The machine hangs up/ stops when the bar puller is supposed to G1 Z-.375
I assume this has something to do with M110 engaged while the chuck open, sensor is activated.
G00 X20. Z10.
M01
M05
G94 (IPM)
T1111 (BAR PULLER)
G00 X6. Z-.375
X1.
M110 (c axis engage)
M15 (tried with & without)
G00 C0.
G01 X0. F50.
M84 (unclamp)
G04 F1.
G01 Z0.02 (hangs up/ doesn't move. Tried G101 too, with no success)
M83 (clamp)
G04 F1.
G00 X2.
M109 (c axis disengage)
G00 X20. Z10.
What am I missing?
Doug.
(picture attached)
G00 X20. Z10.
M01
M05
G94 (IPM)
T1111 (BAR PULLER)
G00 X6. Z-.375
X1.
G00 C0.
G01 X0. F50.
M84 (unclamp)
G04 F1.
M83 (clamp)
G04 F1.
G00 X2.
G00 X20. Z10.
What am I missing?
Doug.
