Hot Headz Marine
Hot Rolled
- Nov 16, 2016
Thanks for the info, I don't understand the 5C chuck and how that would be less headache. Could you steer me a bit, I am pretty darn green.Any chuck will work, they have a backing plate holding with t-nuts onto the 4th itself.
3 jaw is self centering 4 jaw is not normally self centering.
My opinion get a 2 piece jaw chuck that you can precut jaws for ( they will also have a set of hardend master jaws) this way you have the best of both worlds.
depending on the size of your parts a 5c collet nose on that 4th will save you a ton of time money and headach(but only if you do small parts
I spoke with Andrew, he says he has a chuck but will need a backing plate. I kinda like the idea of the collet.. 16c would hold more of the size I will be working with. Mounting the 16c or and or 5c would be purchase something or make something.. Drill holes.. ect... Like Bob said above on the china chuck?I recommend you get the chuck. I can go back and talk to the seller. This is the issue with dealers they try to stiff you every way they can.
With the chuck you can always just hold a 5c collet block but with only 5c you are really limited.
The adapter plate looks like a a series mount those chucks are cheap and easy to come by.
Bobw; There are also collet setups that go bigger. 3J's or 16C's or something like that.[/QUOTE said:Always good advice. I really appreciate it. Ian has been very helpful by going to inspect the old girl. I just signed off on it today so hope I didn't throw myself under the bus again.. HEY.. its no Acroloc at the very least.. LOL I kinda miss that machine. Museum Piece.
In my opinion it is the easiest control in the world to use. Tell it what you want to do, and it literally baby steps you through what you have to do.
I got into a discussion with some friends this morning about this. I was arguing that I thought a fadal was easier than haas and they are all telling me there’s no way a 20 year old control could be any good. But to me it’s way quicker an easier than the haas controls where you gotta enter 30 buttons if you can remember where they are because there’s about 200 of them. But maybe I’m biased because I learned on fadal and own a couple.
Just drop it onto some 1/2" thick, 4x4 pads. or 3x3 or 6x6.
Whatever you have kicking around.
The accelerations on a Fadal are so slow that its not going to move.
So pocketing them isn't that important.
Older 4020's had 4 feet, and in '95 or so, they went to 6 feet.
If you just put the feet onto concrete, that is a TON* of pressure,
much higher than concrete could really deal with..
*Ton. Its actually WAY more than that(Thats wrong). I think the leveling screws are
1" or so in diameter. So even with 6 feet, you are looking at approximately.
*Does Math*
Hey.. What do you know. 2000ish + PSI.
Just moving to some 3x3 pads, even with only 4 feet,
and you are at about 300psi to the concrete.
To your last question, yes, there are leveling screws built into the machine.
And remember, level is just a nice starting point. The goal is to get the
machine cutting square. And a tweak here and there on the feet can make a
difference.
Sounds Like years of experience talking. I understand.
Notice
