Goodway Yama Seiki spindle bearing failure
Likes Likes:  0
Results 1 to 4 of 4
    Jun 2018
    AUSTRALIA
    Default Goodway Yama Seiki spindle bearing failure
    We have 3x Goodway/Yama Seiki GLS 200 turning centres which all have needed spindle bearings replaced within the first 3 years of ownership. One of which was only 3 months old when the spindle bearing went therefore was repaired under warranty.
    Our local agent for these machines has been great during these issues but unfortunately I can’t say the same for Goodway.
    We had Goodway engineers from Taiwan inspect the machines and they believe it was due to a crash or operator error. None of the machines have had any crash, the local agent confirmed this as they are the ones to service these machines but Goodway still wouldn’t take any responsibility and wouldn’t offer us any support to get the machines up and running.
    We have other brand machines running the same parts which are over 15 years old without any issues.
    This must be due to a manufacturing or assembly fault. I can’t see what else would cause premature failure like this.
    I just wanted to share our experience with fellow machinists out there and hopefully it saves others from going through this very expensive exercise.
    Jan 2003
    Canada
    11,202
    5270
    3354
    Is there any signs of coolant making it in the bearings?
    Jun 2018
    AUSTRALIA
    Quote Originally Posted by SND View Post
    No. The technician said there was no traces of coolant inside the bearings.
    Jul 2006
    Hillsboro, New Hampshire
    7,333
    1729
    5091
    Quote Originally Posted by Leemac86 View Post
    Got any pictures of the bearings? Was the failure diagnosed as noise, excess play, degraded finish or ?
    No coolant, but any other debris? If you had multiple failures it should be relatively easy to find a common theme...
