Graphite Milling Machines
Results 1 to 15 of 15
    Mar 2014
    Santa Cruz, California
    40
    Default Graphite Milling Machines
    I'm looking for recommendations for CNC mills for graphite. I'm looking at both the high end of the spectrum and the lower end of the spectrum in terms of features/accuracy.
    These need to be dedicated graphite machines, no retrofit or anything required.
    Anybody got any favorites?
  2. Likes White Lightning liked this post
  3. #2
    Jan 2014
    Washington
    5,262
    948
    2892
    My personal favorites.....
    Makino
    Graphite Machining Centers | Makino
    MC Machinery has the Roku Roku line.
    Hard Milling, Graphite Milling | MC Machinery Systems
    Sep 2015
    CANADA
    Ontario
    107
    52
    43
    I run a Mikron HSM500 "moldmaster" that came setup as a graphite machine.
    We pulled the dust collector off and run copper on it, but it does work well with some quirks. I would be happy to answer any questions you might have about it.
    Mar 2003
    288
    26
    39
    I run a Makino V22. It's on the small end of the line but we don't make anything over about 1/2 cubic inch.
    40000 rpm HSK E32 spindle. Negative pressure enclosure with a dust collector that is almost as big as the machine. We run mostly tungsten copper on it but we do run graphite occasionally if we need to do something larger.
    Extremely accurate and quiet. Quiet enough that with the spindle at 40000 rpm it's not any louder than the Wire EDM next door. Fanuc 31i with the Makino Pro5 software on top. 30 tools standard. Probe and Laser tool setting. If it fits your size requirements it's a great machine. Under 300k.
    I'll answer questions as well if you have any.
    Mar 2012
    Florida
    421
    1307
    160
    I ran a Makino SNC 64 and it was a great machine but the dust collector was sub-par. I bet the newer Makinos likle the V22 are awesome.
  7. Likes Qwan liked this post
  8. #6
    Sep 2006
    Middletown, PA
    496
    170
    84
    I don't know if Milltronics is still trying to market a graphite machine...but the new one I ran 10 yrs. ago was complete joke from day one. Spindle and motion control problems. The black fiberglass housing was the only thing that worked.
  9. #7
    Nov 2011
    CANADA
    623
    40
    188
    Makino F5, even better a Roeder. That's high end in my books. I have also ran low end machines to cut graphite. What's your budget and how much you need to cut. Roeders is a full time job to keep it running... lightning quick.
  10. #8
    Aug 2006
    Wisconsin
    1,696
    776
    770
    +1 For the Roku Roku, ours has been working around the clock for years with a robot. The thing has never had any issues to speak of. Exclusive for carbon only, I suppose some copper if needed, but it does not have a decent way of getting "chips" out.
  11. Likes Qwan liked this post
  12. #9
    Dec 2006
    136
    6
    45
    The HC-658's are awesome.
  13. #10
    Sep 2013
    Minnesota
    328
    116
    78
    On the high end the new Makinos are great machines. On the low end there are a few options out there but only one comes to mind, Chmer machines. They are not super high performance but there claim to fame is oil flooded cutting for zero graphite dust issues.
    I like the old Makino SNC's except for the low power dust extraction which is only a problem if you are hogging with large cutters. Stay away from the 1st generation SNC's!!! Avoid them like the plague, actually. The 1st gen spindles are a very, very poor design and you will fight rebuilding them! Our original spindle lasted a long time but near the end of life we went through numerous spindles which was very expensive. I have heard the newer gen SNC's are good machines.
    Probably my favorite old graphite mill of all time are OKK DGM mills. We had a 400 model which was small and has a very solid design; weight was about 11K pounds. The main casting is tall with the table being stationary. On the top end it is a bridge design and ours had a BT30 30K spindle with ceramic spindle bearings. The bearings last long if you don't crash it. I can't recall what control it had for sure but I want to say it was a Mits 635. Very nice old machines for sure.
  14. Likes vegard liked this post
  15. #11
    Aug 2017
    124
    12
    Well what kind of work are you doing? If its mostly 3ax stuff Id really look into the sodick uh650l... we love ours cant go wrong with the linear motors... 40k spindle standard...
  16. Likes Qwan liked this post
  17. #12
    Jan 2018
    ALAND ISLANDS
    83
    8
    18
    We just recently added a erowa compact 80 robot to a new Roku HC 658ll mill. I was wondering if there was a program like tncremo used to compile programs for a fanuc control. I haven't ran a fanuc control fo over 20 years. The guys at the shop who run our other Roku's act like it's fine to program 150+ electrode calls at the control. I'm used to using tncremo to write pallet programs for our mikron and just dropping them to the Heidenhain control.
  18. #13
    Mar 2012
    Florida
    421
    1307
    160
    My last shop was using a Vibra-Free set up for dust extraction as well as a Makino SNC. Both were great trode machines, I liked the Makino more. Both however lacked at dust collecting. We currently have a Creative that seems to handle the dust well however I dont run this machine. The finishes and accuracy are good on all machines mentioned. I would look into a used SNC if it was still in good shape. Only downfall of that is you will have to buy quite a few different types of oils from Makino and they charge an arm and a leg.
  19. #14
    Feb 2014
    FL
    3,665
    12167
    4283
    Quote Originally Posted by White Lightning View Post
    You're going to get way better results if you start your own thread with this specific question (make the title of the thread very clear as to what you're asking) than replying to an 8 month old post... Most people are going to miss your (barely relevant to the OP) question at the bottom of the post and reply to the OP instead. See PegroPro's reply above mine for confirmation.
  20. #15
    Jan 2018
    ALAND ISLANDS
    83
    8
    18
    Quote Originally Posted by TeachMePlease View Post
    Thanks, I'll give it a shot.
