vtc250mazak
- Nov 19, 2019
hello guys I`m new on here, and I need help to machining snap ring inside(groove)also I just learned this cnc mill. its MAZAK MAZATROL 640 . PLEASE give me an ideas where to start. tahnks
Make the hole, then find a slot mill cutter, or similar to the profile you need (smaller in diameter to the hole), then program the cutter to interpolate the slot at the required depth and size using as many passes as you think you'll need. I typically program to have the leads move to center so there isn't issue of crashing prior to moving in Z. You programming with cam or at the control?
Pretty much what he said.^^^^^
Can you make it go around in a circle? Do you have a circular cutter that is the width of you groove or narrower? Can you put a WPC in the center of the hole? Build on these things and RTFM!!!
Ed.
ED,
I started in center of the hole but machine rapid to the side of the hole ( broke one circular cutter).
what I meant to ask was which units should I be select? I was selected (circle mill)and 0 . Is that not the right units?
Poe.
youre not helping at all.
Notice
