groove inside bore for snapring (cnc mill )
Results 1 to 20 of 20
    Nov 2019
    Ohio
    10
    Default groove inside bore for snapring (cnc mill )
    hello guys I`m new on here, and I need help to machining snap ring inside(groove)also I just learned this cnc mill. its MAZAK MAZATROL 640 . PLEASE give me an ideas where to start. tahnks
    Jan 2014
    Temecula, Ca
    2,909
    1301
    3747
    I would start at the beginning, then keep going till done.
    Seriously, read your post and ask yourself how anyone could even start to give you an answer.
  3. Likes digger doug, Bobw, yardbird, Alloy Mcgraw liked this post
    Aug 2014
    Medicine Hat, Canada
    39
    16
    Make the hole, then find a slot mill cutter, or similar to the profile you need (smaller in diameter to the hole), then program the cutter to interpolate the slot at the required depth and size using as many passes as you think you'll need. I typically program to have the leads move to center so there isn't issue of crashing prior to moving in Z. You programming with cam or at the control?
    Sep 2006
    SW Wisconsin
    519
    23
    132
    Quote Originally Posted by Epic Metal View Post
    Pretty much what he said.^^^^^
    Can you make it go around in a circle? Do you have a circular cutter that is the width of you groove or narrower? Can you put a WPC in the center of the hole? Build on these things and RTFM!!!
    Ed.
    Nov 2019
    Ohio
    10
    Quote Originally Posted by atex57 View Post
    Ed.
    ED,
    I started in center of the hole but machine rapid to the side of the hole ( broke one circular cutter).
    what I meant to ask was which units should I be select? I was selected (circle mill)and 0 . Is that not the right units?
    Poe.
    Nov 2019
    Ohio
    10
    I was programming at the control, what I meant to ask was which UNITS should I be selected? with this conversational machine. For g and m code I machined these things many times.
    Poe.
    Nov 2019
    Ohio
    10
    you`re silly guy, I was working on those thing many times at G and M CODE . But I just learn on this conversational machine about 3 weeks.
    thanks for the help.
  9. #8
    May 2019
    463
    127
    171
    WTF
  10. #9
    Sep 2006
    SW Wisconsin
    519
    23
    132
    Quote Originally Posted by vtc250mazak View Post
    ED,
    Poe.
    Do you mean to say you did not cut air on your first try? Get used to the control without a workpiece. You need to get used to it before you smash more tooling. Do you have your tooling set in the tool table?
    What units are you referring to? Is the tool table set for imperial or metric?
    Ed.
  11. #10
    Nov 2013
    Utah
    4,640
    1222
    2603
    He's using Mazatrol, not G-code. He's referring to the Mazatrol processes as "Units". Circle Mill is a process that the operator selects.
    But vtc250mazak you need a little training before you make parts. You've got the horse before the cart. Or whatever analogy you use where you come from (not Ohio obviously) even the bovine in Ohio speak better. Get training.
    R
  12. #11
    Nov 2019
    Ohio
    10
    youre not helping at all.
  13. #12
    Nov 2019
    Ohio
    10
    For G and M code I was fine but this Mazatrol machine not as good as I think
  14. #13
    Nov 2019
    Ohio
    10
    im from mexico by the way , if you`re building the wall wont ask you no more.
  15. #14
    Nov 2019
    Ohio
    10
    ED, thanks for help. you and I are have two different machine, It hard to explain which im not familiar with this machine. thanks any way.
  16. #15
    Dec 2015
    Illinois
    437
    144
    251
    This won't help you learn mazatrol, but write your program to cut the groove with the G and M code you are confidant with.
  17. #16
    Nov 2013
    Utah
    4,640
    1222
    2603
    Doesnt change the fact that you need training. I don't care if you're from Saturn, you still need training.
    R
  18. Likes digger doug liked this post
  19. #17
    Nov 2019
    Ohio
    10
    my company bought this MAZATROL and let me learn or train . but G and M code Machine too old (25yrs)they will get rid of it. so one way or another I have to learn about this new Mazatrol. but thanks any way
  20. #18
    Nov 2019
    Ohio
    10
    thanks for help
  21. #19
    Oct 2005
    15,683
    No, actually they are.
    The words are in your head, but their not making it to your fingertips.
    Slow down, and re-read what you've posted.
    These people here will give you the shirt off their back, but not if your going to
    ask like this.
  22. Likes Philabuster liked this post
  23. #20
    Nov 2013
    Utah
    4,640
    1222
    2603
    Mazak offers courses (in Spanish too).
    https://www.google.com/url?sa=t&sour...=1574277397026
    You can use EIA (G-code) on the Mazatrol control. You can also manually enter M-codes into your Mazatrol program. If you start demanding that we aren't helping you, by telling you that you need training, that's your own fault. If you're waiting for some schmuck to post a link to online training for Mazatrol in Spanish....I don't know how to help with that.
    R
  24. Likes digger doug, Philabuster liked this post
