Haas 4th axis with slightly jerky rotation during program using simultaneous a and x
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Mar 2019
    Washington
    15
    10
    Default Haas 4th axis with slightly jerky rotation during program using simultaneous a and x
    Machine: Haas TM-3P
    Rotary: HRT210-2-P3
    Lately, I've been working on a cylindrical part that uses both x and a (4th) axes. I am programming in Fusion 360 using the 2D adaptive pocket command and it's generating what looks like a good tool path. I went to do a dry run to see how the rotary would handle it and it did seem to work, but the rotation of the rotary table didn't seem very smooth. It seemed like it was accelerating/decelerating after each line of code. For the part I'm working on, I'm going to need it to be smooth for a nice finish. Just looking at it, and the way it jerks/lags, I know the finish is going to look like crap. On a side note, if I hand jog the 4th axis, it's buttery smooth rotation. This is why I believe it to be a settings/code related issue.
    So far, I have scoured the internet and I've tried a few things:
    1. Enable G187 P3 - did nothing.
    2. Remove G64 from code (disable exact stop) - did nothing.
    3. Messing with 4th axis acceleration parameters - didn't have the balls to mess with it (I'm just going to assume they are good).
    4. Turn smoothing on in Fusion and set tolerance to ridiculously small amount - did nothing.
    5. Enable parameter 315:23 (force all rapid moves to use G01) - did nothing.
    6. Insert M11 (unclamp 4th axis) m-code at beginning of program - 4th already unclamped, did nothing.
    I've been reading some more and it looks like the High Speed Machining option might help me out with this as it can look ahead in the code - preventing unnecessary acceleration/deceleration between blocks. If this works, I'll be quick to report back.
    Here are two videos and a picture to show what's going on. Ignore the fixture currently on the rotary table; it's for another production part unrelated to my tooling job.
    Thanks in advance for any help/advice!
    Feb 2013
    Idaho
    654
    132
    711
    You are going to get a billion lines of code trying to do a tool path like that. Haas machines don't do well with in that situation. Do whatever you can to try and decrease the number of lines of code (decrease tolerance, use an alternate style tool path like Flowline, use G187 P1 etc). High Speed option will help.
  3. Likes controlled_burn liked this post
    Mar 2018
    Wisconsin
    76
    20
    18
    Yup ^ exactly what he said. The Haas I used to run would jerk and jiggle as the amount of lines went up.It fights for exact positioning and tries too hard. That rotory also hated to be turn(unlocked)when milling,even Haas said something about it not being designed for turning while milling. That's at least what I was told.
  5. Likes controlled_burn liked this post
  6. #4
    Jan 2019
    Arizona
    549
    36
    190
    for the 1st 5 years we had our 2009 vf2ss with a 210 we did lots of 4th axis work mainly surfacing, never had any jerking problems. we do have HSM.
    our parameters were factory stock.
    if I recall there was a G code we used to swap the y axis with the A axis(plane). Its kinda like a wrap so to speak( dont know the technical term)I have it written down somewhere I am sure, if I remember I will look for it tomorrow. Basically the Y axis stays put and the a axis(4th ) is the only thing thats moves with Z and A and X moving as necc.
    does gear and spline profiles, spiral, text etc etc
    finish was always extremely nice while rotating.
    if your program is putting out line segments thats one problem why your getting a jerky motion and have very long programs.
    There use to be a video on haas explaining on how to do it thats where I got it from.
    you can always call the haas guys they will be able to tell you, I am sure someone in here will know how.
  7. Likes controlled_burn liked this post
  8. #5
    Jan 2019
    Arizona
    549
    36
    190
    Quote Originally Posted by Delw View Post
    remembered now, cylinder mapping g107
    that being said there should be a way to swap your y with your a A axis in your software as well, my software from 2001 does it, so I am sure the newer stuff will.
  9. #6
    Jun 2019
    Maryland
    141
    23
    I have done a fair amount of 4th axis programming over the years. Most of it without cam. Sometimes I find I have to use a G93 ( inverse timing) in like cutting threads and such . It works the axis in a smoother simultaneous movement around the part.
  10. #7
    Mar 2019
    Washington
    15
    10
    Quote Originally Posted by G00 Proto View Post
    I think you're right. I ended up just running the part because I couldn't figure out a solution to the jerky motion. I wasn't able to tweak the tool path in Fusion to give me fewer lines of code. No matter what I did, there still were thousands just for the wrapped pocket op. I also tried doing a dry run with HSM enabled, but no luck. I've included some pictures below of the part. I think I could have made it look better if I had smaller stepover since I was milling a cylinder with a square end mill. I'll keep playing around with the rotary and tool paths to see if I can get it to run more smoothly.
  11. #8
    Mar 2019
    CANADA
    British Columbia
    Try dropping the feed rate. I've been making similar toolpaths in fusion lately, but in stainless. I loaded up an aluminum blank and cranked the feed rate and had similar jerkiness. I couldn't figure it out because my dry run was smooth. So I started bumping the feed rate down and at a certain threshold the pausing stopped.
    This was with a 2002 VF3 hrt160 , HSM option , inverse time and smoothing applied.
    Not sure what is exactly happening, if I'm hitting the limits of the equipment or the control or the software but going slower sorted it out. And it didn't get gradually better , it just hit a cutoff point where above that it would pause and below it would run continuous .
  12. Likes controlled_burn liked this post
  13. #9
    Jan 2019
    Arizona
    549
    36
    190
    Draw your part flat ie with x and y, draw a finish pass then offset the finish pass every .010 or less step over, then trim those pass's so you dont cut air.
    Then use the g code I mentioned above switch y to A (cylinder mapping g107)
    this will change you y axis to a axis movement.
    now if you cant draw a arc in your software with out segments than you will have segments if you get g3 or g2s and g01s you will be fine.
  14. #10
    Jul 2008
    Milverton, Ontario, Canada
    585
    150
    241
    Post up some code, and I mean a fair bit of it.
    I do tons of work like this on my old ass fadals, no problem.
    I have a feeleing the jerkiness you are seeing is a matter of the nc code not being suitable.
    What year vintage is your machine?
    Need to see the code.
  15. #11
    Feb 2005
    9,018
    13662
    10663
    This is mostly just thoughts and a few questions..
    And I'd like to see a sample of the code also...
    Thought.. A spiral pocket doesn't seem like a code friendly idea when
    you have the A axis involved. (I'm assuming part is oriented along the
    X)
    As your tool is attemting to make a spiral on the cylinder, your X has
    to constantly change feed rates to kind of falsify the Y (if that makes sense).
    I'm guessing that you are seeing a lot of feed rate changes in your segments..
    Who ever said it up there, if you can code it as a wrap, you would eliminate all
    that, and it might get rid of your jerkiness..
    Another thought. On an old Fadal, it can do a simultaneous 4 axis move,
    I'm pretty sure it will even do one with an arc. I know it will do a
    YZJKA move, but it will NOT do it fast. About 7ipm if I remember right.
    So if you can code so that you are only doing 2 axis moves, that might help,
    back and forth instead of a spiral pocket, or at least linear 3 axis moves,
    no spirals..
    Just tossing some thoughts out.
  16. #12
    May 2007
    Mocksville, NC
    102
    I have this problem with our 2015 VF3SS and HRT310 4th axis. I had to adjust the tolerance and smoothing so the cam output G02/03 moves instead of thousands of short G01 movements. This machine does not have the HSM option. By contrast on our new 2019 VF5 - regular machine not an SS - but with the HSM option it runs silky smooth without any filtering of the toolpath.
  17. #13
    Mar 2019
    Washington
    15
    10
    Quote Originally Posted by macds View Post
    Here's the code I used:
    O01001
    (Using high feed G1 F400. instead of G0.)
    (T2 D=0.5 CR=0. - flat end mill)
    (T6 D=0.3125 CR=0. - flat end mill)
    N10 G90 G17
    N15 G20
    N20 G53 G0 Z0.
    (2D Adaptive2)
    N25 T1 M6
    N30 S5990 M3
    N35 G54
    N40 M11
    N45 G0 A11.844
    N50 M8
    N55 G187 P3
    N60 G0 X1.5521 Y0.
    N65 G43 Z0.825 H1
    N70 T2
    N75 G1 A11.844 F303.03
    N80 Z0.7254 F400.
    N85 Z0.725
    N90 X1.5163 Z0.7231 A16.064 F17.241
    N95 X1.4687 Z0.7212 A18.666
    N100 X1.4154 Z0.7194 A19.31
    N105 X1.3634 Z0.7175 A17.912
    N110 X1.3196 Z0.7156 A14.654
    N115 X1.2895 Z0.7137 A9.962
    N120 X1.2772 Z0.7118 A4.447
    N125 X1.2842 Z0.7099 A-1.171
    N130 X1.3096 Z0.7081 A-6.16
    N135 X1.3502 Z0.7062 A-9.869
    N140 X1.4005 Z0.7043 A-11.814
    N145 X1.4541 Z0.7024 A-11.742 F17.748
    N150 X1.504 Z0.7005 A-9.661
    N155 X1.5436 Z0.6986 A-5.844
    N160 X1.5678 Z0.6968 A-0.788
    N165 X1.5734 Z0.6949 A4.848
    N170 X1.5598 Z0.693 A10.328
    N175 X1.5286 Z0.6911 A14.937
    N180 X1.484 Z0.6892 A18.075
    N185 X1.4317 Z0.6874 A19.332
    N190 X1.3786 Z0.6855 A18.544
    N195 X1.3316 Z0.6836 A15.815
    N200 X1.2969 Z0.6817 A11.499 F18.286
    N205 X1.2789 Z0.6798 A6.16
    N210 X1.28 Z0.6779 A0.494
    N215 X1.3001 Z0.6761 A-4.759
    N220 X1.3366 Z0.6742 A-8.915
    N225 X1.3846 Z0.6723 A-11.432
    N230 X1.438 Z0.6704 A-11.981
    N235 X1.4897 Z0.6685 A-10.491
    N240 X1.533 Z0.6666 A-7.155
    N245 X1.5623 Z0.6648 A-2.41
    N250 X1.5738 Z0.6629 A3.126 F18.804
    N255 X1.5659 Z0.661 A8.731
    N260 X1.5397 Z0.6591 A13.674
    N265 X1.4986 Z0.6572 A17.31
    N270 X1.4479 Z0.6554 A19.165
    N275 X1.3943 Z0.6535 A18.997
    N280 X1.3448 Z0.6516 A16.828
    N285 X1.3058 Z0.6497 A12.941
    N290 X1.2824 Z0.6478 A7.842
    N295 X1.2776 Z0.6459 A2.198
    N300 X1.2922 Z0.6441 A-3.257 F19.352
    N305 X1.3241 Z0.6422 A-7.81
    N310 X1.3692 Z0.6403 A-10.868
    N315 X1.4217 Z0.6384 A-12.032
    N320 X1.4746 Z0.6365 A-11.15
    N325 X1.5212 Z0.6346 A-8.337
    N330 X1.5552 Z0.6328 A-3.96
    N335 X1.5724 Z0.6309 A1.41
    N340 X1.5703 Z0.629 A7.073
    N345 X1.5494 Z0.6271 A12.29 F19.873
    N350 X1.5123 Z0.6252 A16.381
    N355 X1.4639 Z0.6234 A18.812
    N360 X1.4104 Z0.6215 A19.265
    N365 X1.3589 Z0.6196 A17.683
    N370 X1.3161 Z0.6177 A14.271
    N375 X1.2876 Z0.6158 A9.475
    N380 X1.277 Z0.6139 A3.919
    N385 X1.2858 Z0.6121 A-1.671
    N390 X1.3128 Z0.6102 A-6.567 F20.423
    N395 X1.3545 Z0.6083 A-10.13
    N400 X1.4054 Z0.6064 A-11.894
    N405 X1.459 Z0.6045 A-11.631
    N410 X1.5082 Z0.6026 A-9.374
    N415 X1.5466 Z0.6008 A-5.418
    N420 X1.5691 Z0.5989 A-0.278
    N425 X1.573 Z0.597 A5.374
    N430 X1.5576 Z0.5951 A10.802 F20.938
    N435 X1.5249 Z0.5932 A15.298
    N440 X1.4793 Z0.5914 A18.275
    N445 X1.4267 Z0.5895 A19.346
    N450 X1.3739 Z0.5876 A18.369
    N455 X1.3278 Z0.5857 A15.474
    N460 X1.2945 Z0.5838 A11.037
    N465 X1.2782 Z0.5819 A5.637
    N470 X1.2811 Z0.5801 A-0.022 F21.48
    N475 X1.3029 Z0.5782 A-5.201
    N480 X1.3406 Z0.5763 A-9.225
    N485 X1.3895 Z0.5744 A-11.569
    N490 X1.443 Z0.5725 A-11.928
    N495 X1.4942 Z0.5706 A-10.254
    N500 X1.5364 Z0.5688 A-6.766
    N505 X1.5642 Z0.5669 A-1.919
    N510 X1.5739 Z0.565 A3.654 F22.05
    N515 X1.566 A8.707
    N520 X1.5431 A13.221
    N525 X1.5077 A16.716
    N530 X1.4635 A18.821
    N535 X1.4111 A19.273
    N540 X1.3605 A17.763
    N545 X1.318 A14.482
    N550 X1.289 A9.84
    N555 X1.277 A3.321
    N560 X1.2916 A-3.139
    N565 X1.3302 A-8.381
    N570 X1.3858 A-11.468
    N575 X1.4486 A-11.846
    N580 X1.5071 A-9.447
    N585 X1.5428 A-5.95
    N590 X1.5659 A-1.42
    N595 X1.5739 A3.654
    N600 X1.5749 A7.02 F26.504
    N605 X1.5759 A10.385
    N610 X1.5787 A11.175
    N615 X1.582 A12.722
    N620 X1.5822 A14.308
    N625 X1.5798 A15.874
    N630 X1.5754 A17.389
    N635 X1.5692 A18.832
    N640 X1.5614 A20.188
    N645 X1.5523 A21.449
    N650 X1.5421 A22.605
    N655 X1.5308 A23.653
    N660 X1.5187 A24.588
    N665 X1.5058 A25.407
    N670 X1.4924 A26.11
    N675 X1.4783 A26.703
    N680 X1.4634 A27.186
    N685 X1.4478 A27.548
    N690 X1.4317 A27.782
    N695 X1.4152 A27.881
    N700 X1.3983 A27.838
    N705 X1.3814 A27.65
    N710 X1.3644 A27.314
    N715 X1.3475 A26.829
    N720 X1.3308 A26.197
    N725 X1.3146 A25.417
    N730 X1.2988 A24.495
    N735 X1.2837 A23.435
    N740 X1.2694 A22.242
    N745 X1.2559 A20.925
    N750 X1.2435 A19.49
    N755 X1.2321 A17.947
    N760 X1.2218 A16.307
    N765 X1.2129 A14.579
    N770 X1.2052 A12.775
    N775 X1.1989 A10.907
    N780 X1.1941 A8.988
    N785 X1.1907 A7.029
    N790 X1.1888 A5.045
    N795 X1.1884 A3.048
    N800 X1.1895 A1.052
    N805 X1.1922 A-0.93
    N810 X1.1963 A-2.886
    N815 X1.202 A-4.802
    N820 X1.209 A-6.665
    N825 X1.2175 A-8.464
    N830 X1.2273 A-10.186
    N835 X1.2384 A-11.82
    N840 X1.2507 A-13.355
    N845 X1.2642 A-14.781
    N850 X1.2786 A-16.09
    N855 X1.2941 A-17.271
    N860 X1.3103 A-18.318
    N865 X1.3274 A-19.224
    N870 X1.345 A-19.983
    N875 X1.3632 A-20.589
    N880 X1.3818 A-21.04
    N885 X1.4007 A-21.331
    N890 X1.4197 A-21.461
    N895 X1.4388 A-21.429
    N900 X1.4578 A-21.235
    N905 X1.4766 A-20.881
    N910 X1.495 A-20.369
    N915 X1.513 A-19.701
    N920 X1.5305 A-18.883
    N925 X1.5473 A-17.92
    N930 X1.5632 A-16.817
    N935 X1.5783 A-15.582
    N940 X1.5925 A-14.223
    N945 X1.6055 A-12.749
    N950 X1.6174 A-11.169
    N955 X1.628 A-9.493
    N960 X1.6386 A-7.485
    N965 X1.6547 A-3.786
    N970 X1.6675 A-0.076
    N975 X1.6752 A2.86
    N980 X1.68 A5.518
    N985 X1.6826 A8.022
    N990 X1.6832 A10.386
    N995 X1.6821 A12.636
    N1000 X1.6794 A14.8
    N1005 X1.675 A16.922
    N1010 X1.6691 A18.999
    N1015 X1.6616 A21.02
    N1020 X1.6526 A22.974
    N1025 X1.6421 A24.848
    N1030 X1.6302 A26.638
    N1035 X1.6168 A28.338
    N1040 X1.602 A29.938
    N1045 X1.5858 A31.425
    N1050 X1.5683 A32.788
    N1055 X1.5495 A34.018
    N1060 X1.5296 A35.1
    N1065 X1.5086 A36.024
    N1070 X1.4867 A36.776
    N1075 X1.4639 A37.348
    N1080 X1.4405 A37.73
    N1085 X1.4166 A37.914
    N1090 X1.3924 A37.894
    N1095 X1.368 A37.667
    N1100 X1.3436 A37.229
    N1105 X1.3194 A36.581
    N1110 X1.2957 A35.723
    N1115 X1.2724 A34.658
    N1120 X1.25 A33.392
    N1125 X1.2284 A31.93
    N1130 X1.2079 A30.279
    N1135 X1.1886 A28.451
    N1140 X1.1706 A26.455
    N1145 X1.1542 A24.304
    N1150 X1.1394 A22.011
    N1155 X1.1263 A19.591
    N1160 X1.1151 A17.06
    N1165 X1.1058 A14.435
    N1170 X1.0985 A11.732
    N1175 X1.0933 A8.97
    N1180 X1.0902 A6.167
    N1185 X1.0892 A3.341
    N1190 X1.0903 A0.512
    N1195 X1.0937 A-2.303
    N1200 X1.0991 A-5.083
    N1205 X1.1067 A-7.811
    N1210 X1.1163 A-10.469
    N1215 X1.1279 A-13.039
    N1220 X1.1414 A-15.504
    N1225 X1.1568 A-17.848
    N1230 X1.1739 A-20.055
    N1235 X1.1926 A-22.111
    N1240 X1.2129 A-24.002
    N1245 X1.2345 A-25.716
    N1250 X1.2573 A-27.242
    N1255 X1.2813 A-28.569
    N1260 X1.3062 A-29.688
    N1265 X1.3318 A-30.594
    N1270 X1.3581 A-31.278
    N1275 X1.3848 A-31.738
    N1280 X1.4118 A-31.969
    N1285 X1.4389 A-31.971
    N1290 X1.4659 A-31.743
    N1295 X1.4926 A-31.287
    N1300 X1.5189 A-30.606
    N1305 X1.5446 A-29.703
    N1310 X1.5695 A-28.585
    N1315 X1.5936 A-27.259
    N1320 X1.6165 A-25.734
    N1325 X1.6382 A-24.019
    N1330 X1.6589 A-22.089
    N1335 X1.6807 A-19.704
    N1340 X1.7018 A-16.99
    N1345 X1.7214 A-14.002
    N1350 X1.7391 A-10.795
    N1355 X1.7541 A-7.476
    N1360 X1.7663 A-4.117
    N1365 X1.7756 A-0.767
    N1370 X1.7822 A2.552
    N1375 X1.7861 A5.839
    N1380 X1.7875 A9.095
    N1385 X1.7864 A12.31
    N1390 X1.7829 A15.471
    N1395 X1.7771 A18.567
    N1400 X1.769 A21.584
    N1405 X1.7587 A24.512
    N1410 X1.7462 A27.339
    N1415 X1.7316 A30.052
    N1420 X1.7149 A32.64
    N1425 X1.6962 A35.088
    N1430 X1.6757 A37.383
    N1435 X1.6533 A39.51
    N1440 X1.6291 A41.456
    N1445 X1.6034 A43.205
    N1450 X1.5762 A44.743
    N1455 X1.5476 A46.056
    N1460 X1.5179 A47.133
    N1465 X1.4872 A47.961
    N1470 X1.4557 A48.531
    N1475 X1.4237 A48.834
    N1480 X1.3913 A48.864
    N1485 X1.3587 A48.618
    N1490 X1.3262 A48.092
    N1495 X1.294 A47.287
    N1500 X1.2623 A46.204
    N1505 X1.2313 A44.848
    N1510 X1.2013 A43.225
    N1515 X1.1725 A41.343
    N1520 X1.1451 A39.212
    N1525 X1.1193 A36.844
    N1530 X1.0952 A34.254
    N1535 X1.0731 A31.457
    N1540 X1.0531 A28.471
    N1545 X1.0354 A25.315
    N1550 X1.0201 A22.009
    N1555 X1.0074 A18.574
    N1560 X0.9972 A15.034
    N1565 X0.9898 A11.412
    N7900 X0.7651 A-109.432
    N7905 X0.8199 A-112.869
    N7910 X0.8763 A-115.985
    N7915 X0.9023 A-117.235
    N7920 X0.9147 A-117.696
    N7925 X0.9277 A-117.914
    N7930 X0.9409 A-117.879
    N7935 X0.9538 A-117.594
    N7940 X0.9807 A-116.727
    N7945 X1.0385 A-114.905
    N7950 X1.0819 A-113.567
    N7955 X1.1421 A-111.749
    N7960 X1.1551 A-110.893 F22.124
    N7965 X1.1627 A-109.488
    N7970 X1.1617 A-107.405 F26.504
    N7975 X1.1491 A-105.799
    N7980 X1.0669 A-100.381
    N7985 X0.9847 A-94.963
    N7990 X0.9025 A-89.545
    N7995 X0.8203 A-84.126
    N8000 X0.7381 A-78.708
    N8005 X0.6559 A-73.29
    N8010 X0.5737 A-67.872
    N8015 X0.4915 A-62.454
    N8020 X0.4752 A-61.954
    N8025 X0.4587 A-62.434
    N8030 X0.448 A-63.588 F22.124
    N8035 X0.4438 A-65.142
    N8040 A-82.799 F26.504
    N8045 X0.4445 A-84.383
    N8050 X0.4468 A-86.235
    N8055 X0.4508 A-88.179
    N8060 X0.457 A-90.376
    N8065 X0.4668 A-93.035
    N8070 X0.479 A-95.69
    N8075 X0.4972 A-98.948
    N8080 X0.5193 A-102.272
    N8085 X0.5501 A-106.179
    N8090 X0.5898 A-110.475
    N8095 X0.6378 A-114.898
    N8100 X0.689 A-118.911
    N8105 X0.735 A-122.047
    N15595 X2.4738 A-27.676
    N15600 X2.4736 A-32.132
    N15605 X2.4734 A-36.588
    N15610 X2.4731 A-41.044
    N15615 X2.4729 A-45.5
    N15620 X2.4726 A-49.956
    N15625 X2.4724 A-54.412
    N15630 X2.4721 A-58.868
    N15635 X2.4719 A-63.324
    N15640 X2.4717 A-67.78
    N15645 X2.4837 A-70.403
    N15650 X2.4977 A-71.056 F23.063
    N15655 X2.5129 A-70.928
    N15660 X2.5274 A-70.345 F27.629
    N15665 X2.5771 A-68.199
    N15670 X2.6141 A-66.459
    N15675 X2.6286 A-65.756
    N15680 X2.672 A-63.494
    N15685 X2.6864 A-62.672
    N15690 X2.7153 A-60.912
    N15695 X2.73 A-59.915
    N15700 X2.747 A-58.534
    N15705 X2.7657 A-56.757
    N15710 X2.7847 A-54.635
    N15715 X2.8064 A-51.782
    N15720 X2.8281 A-48.405
    N15725 X2.8516 A-44.034
    N15730 X2.8761 A-38.476
    N15735 X2.8982 A-32.163
    N15740 X2.916 A-25.697
    N15745 X2.9231 A-22.414
    N15750 X2.9302 A-19.131
    N15755 X2.9356 A-15.812
    N15760 X2.941 A-12.494
    N15765 X2.9463 A-7.885
    N15770 X2.9465 A-7.456
    N15775 X2.9478 A-3.99
    N15780 X2.9485 A0.597
    N15785 A6.712
    N15790 X2.9478 A11.298
    N15795 X2.9462 A15.885
    N15800 X2.9455 A17.413
    N15805 X2.9428 A22.
    N15810 X2.9389 A26.586
    N15815 X2.9372 A28.115
    N15820 X2.9322 A32.354
    N15825 X2.9293 A34.23
    N15830 X2.924 A37.288
    N15835 X2.9171 A40.345
    N15840 X2.9136 A41.874
    N15845 X2.9094 A43.403
    N15850 X2.8942 A47.989
    N15855 X2.8876 A49.518
    N15860 X2.8807 A51.047
    N15865 X2.8743 A52.26
    N15870 X2.8638 A54.104
    N15875 X2.8536 A55.633
    N15880 X2.8454 A56.802
    N15885 X2.83 A58.691
    N15890 X2.8165 A60.117
    N15895 X2.7828 A63.277
    N15900 X2.7731 A64.156
    N15905 X2.7648 A64.806
    N15910 X2.7587 A65.249
    N15915 X2.7298 A67.285
    N15920 X2.7213 A67.864
    N15925 X2.6999 A69.153
    N15930 X2.685 A69.532 F23.063
    N15935 X2.6702 A69.119
    N15940 X2.6583 A67.888 F27.629
    N15945 X2.6541 A66.186
    N15950 X2.6546 A62.304
    N15955 X2.6551 A58.422
    N15960 X2.6555 A54.54
    N15965 X2.656 A50.658
    N15970 X2.6565 A46.776
    N15975 X2.657 A42.894
    N15980 X2.6575 A39.012
    N15985 X2.6579 A35.13
    N15990 X2.6584 A31.248
    N15995 X2.6589 A27.366
    N16000 X2.6594 A23.484
    N16005 X2.6599 A19.603
    N16010 X2.6603 A15.721
    N16015 X2.6608 A11.839
    N16020 X2.6613 A7.957
    N16025 X2.6618 A4.075
    N16030 X2.6623 A0.193
    N16035 X2.6627 A-3.689
    N16040 X2.6632 A-7.571
    N16045 X2.6637 A-11.453
    N16050 X2.6642 A-15.335
    N16055 X2.6646 A-19.217
    N16060 X2.6651 A-23.099
    N16065 X2.6656 A-26.981
    N16070 X2.6661 A-30.863
    N16075 X2.6666 A-34.745
    N16080 X2.667 A-38.627
    N16085 X2.6675 A-42.509
    N16090 X2.668 A-46.391
    N16095 X2.6685 A-50.273
    N16100 X2.669 A-54.154
    N16105 X2.6694 A-58.036
    N16110 X2.6739 A-59.694
    N16115 X2.6856 A-60.889
    N16120 X2.7005 A-61.297 F23.063
    N16125 X2.7153 A-60.912
    N16130 X2.7212 A-60.555 F27.629
    N16135 X2.7298 A-59.971
    N16140 X2.7587 A-57.93
    N16145 X2.7646 A-57.498
    N16150 X2.7731 A-56.831
    N16155 X2.7827 A-55.969
    N16160 X2.8165 A-52.826
    N16165 X2.8302 A-51.382
    N16170 X2.8454 A-49.51
    N16175 X2.8537 A-48.325
    N16180 X2.8637 A-46.796
    N16185 X2.8743 A-44.908
    N16190 X2.8804 A-43.739
    N16195 X2.8888 A-41.893
    N16200 X2.894 A-40.681
    N16205 X2.9095 A-36.095
    N16210 X2.9137 A-34.566
    N16215 X2.9207 A-31.508
    N16220 X2.9241 A-29.979
    N16225 X2.9294 A-26.922
    N16230 X2.9322 A-25.105
    N16235 X2.9354 A-22.335
    N16240 X2.9372 A-20.807
    N16245 X2.9389 A-19.278
    N16250 X2.9427 A-14.691
    N16255 X2.9454 A-10.105
    N16260 X2.9461 A-8.576
    N16265 X2.9465 A-7.456
    N16270 X2.9428 A-5.886 F23.063
    N16275 X2.9325 A-4.691
    N16280 X2.9141 Z0.5512 A-3.402
    N16285 X2.9065 Z0.5732 A-2.869 F21.805
    N16290 Z0.7254 F400.
    N16295 X0.4684 A-7.187 F344.64
    N16300 Z0.6045 F400.
    N16305 Z0.5732 F20.
    N16310 X0.4638 Z0.5512 A-8.018 F21.805
    N16315 X0.4525 Z0.542 A-10.026 F22.68
    N16320 X0.4438 A-13.163
    N16325 A-43.739 F27.629
    N16330 X0.4451 A-46.538
    N16335 X0.4481 A-48.984
    N16340 X0.4543 A-52.036
    N16345 X0.4634 A-55.247
    N16350 X0.4781 A-59.23
    N16355 X0.4971 A-63.381
    N16360 X0.5241 A-68.23
    N16365 X0.5599 A-73.608
    N16370 X0.6005 A-78.79
    N16375 X0.6446 A-83.653
    N16380 X0.6915 A-88.208
    N16385 X0.7409 A-92.459
    N16390 X0.7926 A-96.392
    N16395 X0.8464 A-100.001
    N16400 X0.9021 A-103.275
    N16405 X0.9594 A-106.205
    N16410 X1.0183 A-108.786
    N16415 X1.0784 A-111.011
    N16420 X1.1021 A-111.735
    N16425 X1.1154 A-112.003
    N16430 X1.1289 A-112.007
    N16435 X1.1421 A-111.749
    N16440 X1.1975 A-110.107
    N16445 X1.2553 A-108.421
    N16450 X1.3276 A-106.349
    N16455 X1.4143 A-103.904
    N16460 X1.4169 A-103.832
    N16465 X1.4301 A-103. F23.063
    N16470 X1.4379 A-101.609
    N16475 X1.4369 A-99.444 F27.629
    N16480 X1.4235 A-97.806
    N16485 X1.3652 A-94.255
    N16490 X1.3069 A-90.704
    N16495 X1.2486 A-87.153
    N16500 X1.1903 A-83.602
    N16505 X1.132 A-80.051
    N16510 X1.0737 A-76.501
    N16515 X1.0154 A-72.95
    N16520 X0.9571 A-69.399
    N16525 X0.8987 A-65.848
    N16530 X0.8404 A-62.297
    N16535 X0.7821 A-58.746
    N16540 X0.7238 A-55.195
    N16545 X0.6655 A-51.644
    N16550 X0.6072 A-48.093
    N16555 X0.5489 A-44.542
    N16560 X0.4906 A-40.991
    N16565 X0.4746 A-40.551
    N16570 X0.4587 A-41.031
    N16575 X0.448 A-42.185 F23.063
    N16580 X0.4438 A-43.739
    N16585 A-65.142 F27.629
    N16590 X0.4446 A-66.845
    N16595 X0.4469 A-68.757
    N16600 X0.4515 A-70.996
    N16605 X0.4591 A-73.693
    N16610 X0.4693 A-76.45
    N16615 X0.485 A-79.878
    N16620 X0.5047 A-83.418
    N16625 X0.5326 A-87.61
    N16630 X0.5694 A-92.302
    N16635 X0.6139 A-97.122
    N16640 X0.6617 A-101.569
    N16645 X0.7123 A-105.669
    N16650 X0.7651 A-109.432
    N16655 X0.8199 A-112.869
    N16660 X0.8763 A-115.985
    N16665 X0.9023 A-117.235
    N16670 X0.9147 A-117.696
    N16675 X0.9277 A-117.914
    N16680 X0.9409 A-117.879
    N16685 X0.9538 A-117.594
    N16690 X0.9807 A-116.727
    N16695 X1.0385 A-114.905
    N16700 X1.0819 A-113.567
    N16705 X1.1421 A-111.749
    N16710 X1.1551 A-110.893 F23.063
    N16715 X1.1627 A-109.488
    N16720 X1.1617 A-107.405 F27.629
    N16725 X1.1491 A-105.799
    N16730 X1.0669 A-100.381
    N16735 X0.9847 A-94.963
    N16740 X0.9025 A-89.545
    N16745 X0.8203 A-84.126
    N16750 X0.7381 A-78.708
    N16755 X0.6559 A-73.29
    N16760 X0.5737 A-67.872
    N16765 X0.4915 A-62.454
    N16770 X0.4752 A-61.954
    N16775 X0.4587 A-62.434
    N16780 X0.448 A-63.588 F23.063
    N16785 X0.4438 A-65.142
    N16790 A-82.799 F27.629
    N16795 X0.4445 A-84.383
    N16800 X0.4468 A-86.235
    N16805 X0.4508 A-88.179
    N16810 X0.457 A-90.376
    N16815 X0.4668 A-93.035
    N16820 X0.479 A-95.69
    N16825 X0.4972 A-98.948
    N16830 X0.5193 A-102.272
    N16835 X0.5501 A-106.179
    N16840 X0.5898 A-110.475
    N16845 X0.6378 A-114.898
    N16850 X0.689 A-118.911
    N16855 X0.735 A-122.047
    N16860 X0.7466 A-122.684
    N16865 X0.759 A-123.096
    N16870 X0.7718 A-123.268
    N16875 X0.7848 A-123.196
    N16880 X0.7975 A-122.881
    N16885 X0.8361 A-121.524
    N16890 X0.894 A-119.558
    N16895 X0.9373 A-118.127
    N16900 X0.9538 A-117.594
    N16905 X0.9666 A-116.71 F23.063
    N16910 X0.9739 A-115.288
    N16915 X0.9727 A-113.255 F27.629
    N16920 X0.9604 A-111.684
    N16925 X0.9019 A-107.74
    N16930 X0.8433 A-103.795
    N16935 X0.7847 A-99.851
    N16940 X0.7261 A-95.906
    N16945 X0.6675 A-91.962
    N16950 X0.6089 A-88.017
    N16955 X0.5504 A-84.073
    N16960 X0.4918 A-80.128
    N16965 X0.4753 A-79.611
    N16970 X0.4587 A-80.092
    N16975 X0.448 A-81.246 F23.063
    N16980 X0.4438 A-82.799
    N16985 A-98.775 F27.629
    N16990 X0.4447 A-100.714
    N16995 X0.4466 A-102.286
    N17000 X0.4503 A-104.111
    N17005 X0.4565 A-106.271
    N17010 X0.4645 A-108.427
    N17015 X0.4764 A-111.011
    N17020 X0.492 A-113.805
    N17025 X0.5124 A-116.877
    N17030 X0.5387 A-120.219
    N17035 X0.5719 A-123.805
    N17040 X0.5992 A-126.31
    N17045 X0.6025 A-126.573
    N17050 X0.6149 A-127.353
    N17055 X0.6286 A-127.859
    N17060 X0.6429 A-128.072
    N17065 X0.6573 A-127.983
    N17070 X0.6712 A-127.596
    N17075 X0.6916 A-126.796
    N17080 X0.735 A-125.155
    N17085 X0.7494 A-124.615
    N17090 X0.7928 A-123.046
    N17095 X0.7975 A-122.881
    N17100 X0.8101 A-121.964 F23.063
    N17105 X0.8171 A-120.524
    N17110 X0.8155 A-118.528 F27.629
    N17115 X0.8033 A-116.994
    N17120 X0.7254 A-111.771
    N17125 X0.6475 A-106.547
    N17130 X0.5696 A-101.324
    N17135 X0.4917 A-96.101
    N17140 X0.4753 A-95.587
    N17145 X0.4587 A-96.068
    N17150 X0.448 A-97.221 F23.063
    N17155 X0.4438 A-98.775
    N17160 A-114.063 F27.629
    N17165 X0.4447 A-116.
    N17170 X0.4466 A-117.572
    N17175 X0.4503 A-119.376
    N17180 X0.4555 A-121.191
    N17185 X0.4633 A-123.292
    N17190 X0.4721 A-125.201
    N17195 X0.4822 A-127.004
    N17200 X0.4924 A-128.519
    N17205 X0.4972 A-129.129
    N17210 X0.5065 A-130.112
    N17215 X0.5173 A-130.903
    N17220 X0.5293 A-131.474
    N17225 X0.5421 A-131.809
    N17230 X0.5552 A-131.895
    N17235 X0.5683 A-131.73
    N17240 X0.5809 A-131.319
    N17245 X0.5929 A-130.312 F23.063
    N17250 X0.5989 A-128.824
    N17255 X0.5937 A-126.423 F27.629
    N17260 X0.5704 A-122.89
    N17265 X0.5471 A-119.357
    N17270 X0.5239 A-115.824
    N17275 X0.5006 A-112.292
    N17280 X0.4814 A-110.946
    N17285 X0.4587 A-111.356
    N17290 X0.448 A-112.509 F23.063
    N17295 X0.4438 A-114.063
    N17300 A-127.822 F27.629
    N17305 X0.4445 A-129.406
    N17310 X0.4491 A-130.704
    N17315 X0.4562 A-131.867
    N17320 X0.4655 A-132.842
    N17325 X0.4766 A-133.582
    N17330 X0.4889 A-134.054
    N17335 X0.5019 A-134.235
    N17340 X0.5149 A-134.117
    N17345 X0.5275 A-133.705
    N17350 X0.5392 A-132.673 F23.063
    N17355 X0.545 A-131.173
    N17360 X0.5425 A-129.376 F27.629
    N17365 X0.5315 A-127.986
    N17370 X0.4925 A-125.2
    N17375 X0.4757 A-124.635
    N17380 X0.4587 A-125.115
    N17385 X0.448 A-126.269 F23.063
    N17390 X0.4438 A-127.822
    N17395 A-132.409 F27.629
    N17400 X0.4442 A-133.034
    N17405 X0.4449 A-133.346
    N17410 X0.4458 A-133.658
    N17415 X0.447 A-133.938
    N17420 X0.449 A-134.309
    N17425 X0.4518 A-134.68
    N17430 X0.4539 A-134.92
    N17435 X0.456 A-135.119
    N17440 X0.4603 A-135.423
    N17445 X0.4611 A-135.466
    N17450 X0.4645 A-135.629
    N17455 X0.4679 A-135.743
    N17460 X0.4713 A-135.813
    N17465 X0.4748 A-135.842
    N17470 X0.4784 A-135.83
    N17475 X0.482 A-135.773
    N17480 X0.4856 A-135.669
    N17485 X0.4902 A-135.466
    N17490 X0.5037 A-134.809
    N17495 X0.5326 A-133.47
    N17500 X0.5558 A-132.409
    N17505 X0.6049 A-130.285
    N17510 X0.6338 A-129.087
    N17515 X0.6482 A-128.5
    N17520 X0.6712 A-127.596
    N17525 X0.6835 A-126.632 F23.063
    N17530 X0.69 A-125.167
    N17535 X0.6942 Z0.5512 A-122.873
    N17540 X0.6959 Z0.5732 A-121.923 F21.805
    N17545 Z0.825 F400.
    N17550 G53 G0 Z0.
    (2D Contour4)
    N17555 M11
    N17560 G0 A-169.305
    N17565 G187 P3
    N17570 G0 X0.0389 Y0.
    N17575 G43 Z1.225 H1
    N17580 G1 A-169.305 F204.082
    N17585 Z0.825 F400.
    N17590 Z0.6644 F20.
    N17595 Z0.5732
    N17600 X0.0394 Z0.5678 A-169.319 F21.805
    N17605 X0.0407 Z0.5626 A-169.361
    N17610 X0.0429 Z0.5576 A-169.43
    N17615 X0.0459 Z0.5532 A-169.524 F22.416
    N17620 X0.0496 Z0.5493 A-169.64
    N17625 X0.0539 Z0.5462 A-169.774
    N17630 X0.0586 Z0.5439 A-169.923
    N17635 X0.0637 Z0.5425 A-170.081 F22.983
    N17640 X0.0689 Z0.542 A-170.244
    N17645 X0.0989 A-171.183
    N17650 X0.1042 A-171.298
    N17655 X0.1096 A-171.313
    N17660 X0.115 A-171.228
    N17665 X0.1202 A-171.046
    N17670 X0.125 A-170.771
    N17675 X0.1292 A-170.413
    N17680 X0.1329 A-169.982
    N17685 X0.1357 A-169.491
    N17690 X0.1377 A-168.955
    N17695 X0.1413 A-167.654 F27.629
    N17700 X0.1438 A-166.844
    N17705 X0.1467 A-166.05
    N17710 X0.1517 A-164.78
    N17715 X0.1545 A-164.107
    N17720 X0.1575 A-163.447
    N17725 X0.1636 A-162.215
    N17730 X0.1695 A-161.116
    N17735 X0.1766 A-159.926
    N17740 X0.1823 A-159.021
    N17745 X0.19 A-157.879
    N17750 X0.1955 A-157.13
    N17755 X0.2038 A-156.042
    N17760 X0.2088 A-155.415
    N17765 X0.2175 A-154.385
    N17770 X0.2224 A-153.836
    N17775 X0.2314 A-152.863
    N17780 X0.2361 A-152.377
    N17785 X0.2454 A-151.453
    N17790 X0.2499 A-151.031
    N17795 X0.2595 A-150.148
    N17800 X0.2653 A-149.643
    N17805 X0.2853 A-147.973
    N17810 X0.2913 A-147.496
    N17815 X0.3124 A-145.909
    N17820 X0.3173 A-145.559
    N17825 X0.3393 A-144.031
    N17830 X0.3436 A-143.738
    N17835 X0.3664 A-142.267
    N17840 X0.3703 A-142.022
    N17845 X0.3938 A-140.605
    N17850 X0.3973 A-140.398
    N17855 X0.4213 A-139.035
    N17860 X0.4245 A-138.861
    N17865 X0.4488 A-137.551
    N17870 X0.4517 A-137.401
    N17875 X0.4763 A-136.143
    N17880 X0.4789 A-136.018
    N17885 X0.5036 A-134.811
    N17890 X0.5058 A-134.707
    N17895 X0.5304 A-133.552
    N17900 X0.5323 A-133.467
    N17905 X0.5567 A-132.365
    N17910 X0.5583 A-132.293
    N17915 X0.5823 A-131.242
    N17920 X0.5838 A-131.177
    N17925 X0.6076 A-130.166
    N17930 X0.609 A-130.107
    N17935 X0.6327 A-129.125
    N17940 X0.634 A-129.073
    N17945 X0.6579 A-128.109
    N17950 X0.6591 A-128.062
    N17955 X0.6832 A-127.113
    N17960 X0.6843 A-127.07
    N17965 X0.7087 A-126.133
    N17970 X0.7097 A-126.094
    N17975 X0.7344 A-125.169
    N17980 X0.7353 A-125.134
    N17985 X0.7602 A-124.219
    N17990 X0.7611 A-124.186
    N17995 X0.7861 A-123.28
    N18000 X0.787 A-123.251
    N18005 X0.8123 A-122.353
    N18010 X0.8131 A-122.326
    N18015 X0.8387 A-121.435
    N18020 X0.8394 A-121.41
    N18025 X0.8652 A-120.526
    N18030 X0.8659 A-120.503
    N18035 X0.8918 A-119.628
    N18040 X0.8925 A-119.606
    N18045 X0.9186 A-118.739
    N18050 X0.9192 A-118.718
    N18055 X0.9455 A-117.859
    N18060 X0.946 A-117.841
    N18065 X0.9724 A-116.991
    N18070 X0.9729 A-116.973
    N18075 X0.9993 A-116.133
    N18080 X0.9998 A-116.116
    N18085 X1.0263 A-115.285
    N18090 X1.0267 A-115.27
    N18095 X1.0532 A-114.447
    N18100 X1.0537 A-114.433
    N18105 X1.0801 A-113.62
    N18110 X1.0806 A-113.607
    N18115 X1.107 A-112.802
    N18120 X1.1074 A-112.79
    N18125 X1.1339 A-111.994
    N18130 X1.1342 A-111.983
    N18135 X1.1606 A-111.195
    N18140 X1.1609 A-111.185
    N18145 X1.1873 A-110.406
    N18150 X1.1876 A-110.396
    N18155 X1.2139 A-109.625
    N18160 X1.2142 A-109.617
    N20440 X2.3072 A-274.298
    N20445 X2.2524 A-272.531
    N20450 X2.1966 A-270.792
    N20455 X2.14 A-269.078
    N20460 X2.0828 A-267.387
    N20465 X2.0253 A-265.719
    N20470 X1.9674 A-264.071
    N20475 X1.9094 A-262.442
    N20480 X1.8514 A-260.83
    N20485 X1.7936 A-259.233
    N20490 X1.7361 A-257.653
    N20495 X1.6791 A-256.088
    N20500 X1.6226 A-254.541
    N20505 A-254.54 F23.96
    N20510 X1.5669 A-253.012 F27.629
    N20515 X1.5668 A-253.008
    N20520 X1.512 A-251.5
    N20525 X1.5118 A-251.494
    N20530 X1.4578 A-250.
    N20535 X1.4575 A-249.992
    N20540 X1.4034 A-248.481
    N20545 X1.403 A-248.471
    N20550 X1.3477 A-246.914
    N20555 X1.3473 A-246.902
    N20560 X1.2909 A-245.295
    N20565 X1.2904 A-245.28
    N20570 X1.2331 A-243.628
    N20575 X1.2325 A-243.611
    N20580 X1.1748 A-241.917
    N20585 X1.174 A-241.895
    N20590 X1.1161 A-240.163
    N20595 X1.1152 A-240.137
    N20600 X1.0571 A-238.364
    N20605 X1.0562 A-238.334
    N20610 X0.9981 A-236.519
    N20615 X0.997 A-236.484
    N20620 X0.9392 A-234.627
    N20625 X0.9379 A-234.586
    N20630 X0.8806 A-232.688
    N20635 X0.8791 A-232.638
    N20640 X0.8226 A-230.699
    N20645 X0.8209 A-230.64
    N20650 X0.7653 A-228.659
    N20655 X0.7633 A-228.588
    N20660 X0.7089 A-226.563
    N20665 X0.7067 A-226.478
    N20670 X0.6536 A-224.408
    N20675 X0.6509 A-224.302
    N20680 X0.5989 A-222.16
    N20685 X0.5966 A-222.061
    N20690 X0.5703 A-220.929
    N20695 X0.5686 A-220.854
    N20700 X0.5419 A-219.663
    N20705 X0.54 A-219.574
    N20710 X0.5129 A-218.322
    N20715 X0.5107 A-218.215
    N20720 X0.4835 A-216.903
    N20725 X0.481 A-216.776
    N20730 X0.4539 A-215.404
    N20735 X0.4509 A-215.248
    N20740 X0.4242 A-213.816
    N20745 X0.4207 A-213.625
    N20750 X0.3944 A-212.13
    N20755 X0.3905 A-211.898
    N20760 X0.3648 A-210.337
    N20765 X0.3603 A-210.052
    N20770 X0.3355 A-208.423
    N20775 X0.3304 A-208.073
    N20780 X0.3066 A-206.372
    N20785 X0.3024 A-206.056
    N20790 X0.2909 A-205.177
    N20795 X0.2875 A-204.908
    N20800 X0.2764 A-204.002
    N20805 X0.2725 A-203.676
    N20810 X0.2617 A-202.737
    N20815 X0.2574 A-202.351
    N20820 X0.2469 A-201.371
    N20825 X0.2423 A-200.923
    N20830 X0.2321 A-199.894
    N20835 X0.2273 A-199.386
    N20840 X0.2175 A-198.301
    N20845 X0.2124 A-197.708
    N20850 X0.2029 A-196.559
    N20855 X0.1968 A-195.763
    N20860 X0.1879 A-194.542
    N20865 X0.1813 A-193.545
    N20870 X0.1733 A-192.254
    N20875 X0.1666 A-191.074
    N20880 X0.1597 A-189.725
    N20885 X0.1564 A-189.027
    N20890 X0.1533 A-188.314
    N20895 X0.1477 A-186.918
    N20900 X0.1433 A-185.682
    N20905 X0.1411 A-184.97
    N20910 X0.1384 A-184.045
    N20915 X0.1366 A-183.326
    N20920 X0.1347 A-182.785 F23.063
    N20925 X0.132 A-182.287
    N20930 X0.1285 A-181.846
    N20935 X0.1243 A-181.476
    N20940 X0.1196 A-181.188
    N20945 X0.1145 A-180.992
    N20950 X0.1091 A-180.892
    N20955 X0.1037 F20.
    N20960 X0.0983 A-180.993 F23.063
    N20965 X0.0681 A-181.85
    N20970 X0.0629 Z0.5425 A-181.999
    N20975 X0.0578 Z0.5439 A-182.143
    N20980 X0.053 Z0.5462 A-182.278
    N20985 X0.0487 Z0.5493 A-182.401
    N20990 X0.045 Z0.5532 A-182.506
    N20995 X0.042 Z0.5576 A-182.592 F22.416
    N21000 X0.0398 Z0.5626 A-182.655
    N21005 X0.0384 Z0.5678 A-182.694
    N21010 X0.038 Z0.5732 A-182.707 F21.805
    N21015 Z1.225 F400.
    N21020 M5
    N21025 G53 G0 Z0.
    (2D Contour5)
    N21030 M9
    N21035 M1
    N21040 T4 M6
    N21045 S5500 M3
    N21050 G54
    N21055 M11
    N21060 G0 A-178.936
    N21065 M8
    N21070 G187 P3
    N21075 G0 X-0.1125 Y0.
    N21080 G43 Z1.225 H4
    N21085 T6
    N21090 G1 A-178.936 F204.082
    N21095 Z0.825 F400.
    N21100 Z0.7244 F20.
    N21105 Z0.615
    N21110 X-0.112 Z0.6079
    N21115 X-0.1105 Z0.6009
    N21120 X-0.108 Z0.5942
    N21125 X-0.1046 Z0.588
    N21130 X-0.1003 Z0.5823
    N21135 X-0.0952 Z0.5772
    N21140 X-0.0895 Z0.5729
    N21145 X-0.0833 Z0.5695
    N21150 X-0.0766 Z0.567
    N21155 X-0.0696 Z0.5655
    N21160 X-0.0625 Z0.565
    N21165 X-0.0125
    N21170 X-0.0054 A-178.883 F22.124
    N21175 X0.0016 A-178.722
    N21180 X0.0083 A-178.459
    N21185 X0.0145 A-178.097
    N21190 X0.0202 A-177.645
    N21195 X0.0253 A-177.112
    N21200 X0.0296 A-176.508
    N21205 X0.033 A-175.847
    N21210 X0.0355 A-175.14
    N21215 X0.037 A-174.403
    N21220 X0.0375 A-173.651
    N21225 A5.744 F18.252
    N21230 A180.959 F22.124
    N21235 X0.037 A181.711
    N21240 X0.0355 A182.448
    N21245 X0.033 A183.155
    N21250 X0.0296 A183.817
    N21255 X0.0253 A184.42
    N21260 X0.0202 A184.954
    N21265 X0.0145 A185.406
    N21270 X0.0083 A185.767
    N21275 X0.0016 A186.031
    N21280 X-0.0054 A186.191
    N21285 X-0.0125 A186.245
    N21290 X-0.0625 F20.
    N21295 X-0.0696 Z0.5655
    N21300 X-0.0766 Z0.567
    N21305 X-0.0833 Z0.5695
    N21310 X-0.0895 Z0.5729
    N21315 X-0.0952 Z0.5772
    N21320 X-0.1003 Z0.5823
    N21325 X-0.1046 Z0.588
    N21330 X-0.108 Z0.5942
    N21335 X-0.1105 Z0.6009
    N21340 X-0.112 Z0.6079
    N21345 X-0.1125 Z0.615
    N21350 Z0.825 F400.
    N21355 A184.818 F303.03
    N21360 A183.392
    N21365 A181.965
    N21370 A180.539
    N21375 A179.112
    N21380 A177.686
    N21385 A176.259
    N21390 A174.833
    N21395 A173.406
    N21400 A171.98
    N21405 A170.553
    N21410 A169.127
    N21415 A167.7
    N21420 A166.274
    N21425 A164.847
    N21430 A163.421
    N21435 A161.994
    N21440 A160.568
    N21445 A159.141
    N21450 A157.715
    N21455 A156.288
    N21460 A154.862
    N21465 A153.436
    N21470 A152.009
    N21475 A150.583
    N21480 A149.156
    N21485 A147.73
    N21490 A146.303
    N21495 A144.877
    N21500 A143.45
    N21505 A142.024
    N21510 A140.597
    N21515 A139.171
    N21520 A137.744
    N21525 A136.318
    N21530 A134.891
    N21535 A133.465
    N21540 A132.038
    N21545 A130.612
    N21550 A129.185
    N21555 A127.759
    N21560 A126.332
    N21565 A124.906
    N21570 A123.479
    N21575 A122.053
    N21580 A120.626
    N21585 A119.2
    N21590 A117.773
    N21595 A116.347
    N21600 A114.92
    N21605 A113.494
    N21610 A112.067
    N21615 A110.641
    N21620 A109.214
    N21625 A107.788
    N21630 A106.361
    N21635 A104.935
    N21640 A103.508
    N21645 A102.082
    N21650 A100.655
    N21655 A99.229
    N21660 A97.802
    N21665 A96.376
    N21670 A94.949
    N21675 A93.523
    N21680 A92.096
    N21685 A90.67
    N21690 A89.244
    N21695 A87.817
    N21700 A86.391
    N21705 A84.964
    N21710 A83.538
    N21715 A82.111
    N21720 A80.685
    N21725 A79.258
    N21730 A77.832
    N21735 A76.405
    N21740 A74.979
    N21745 A73.552
    N21750 A72.126
    N21755 A70.699
    N21760 A69.273
    N21765 A67.846
    N21770 A66.42
    N21775 A64.993
    N21780 A63.567
    N21785 A62.14
    N21790 A60.714
    N21795 A59.287
    N21800 A57.861
    N21805 A56.434
    N21810 A55.008
    N21815 A53.581
    N21820 A52.155
    N21825 A50.728
    N21830 A49.302
    N21835 A47.875
    N21840 A46.449
    N21845 A45.022
    N21850 A43.596
    N21855 A42.169
    N21860 A40.743
    N21865 A39.316
    N21870 A37.89
    N21875 A36.463
    N21880 A35.037
    N21885 A33.61
    N21890 A32.184
    N21895 A30.757
    N21900 A29.331
    N21905 A27.904
    N21910 A26.478
    N21915 A25.052
    N21920 A23.625
    N21925 A22.199
    N21930 A20.772
    N21935 A19.346
    N21940 A17.919
    N21945 A16.493
    N21950 A15.066
    N21955 A13.64
    N21960 A12.213
    N21965 A10.787
    N21970 A9.36
    N21975 A7.934
    N21980 A6.507
    N21985 A5.081
    N21990 A3.654
    N21995 A2.228
    N22000 A0.801
    N22005 A-0.625
    N22010 A-2.052
    N22015 A-3.478
    N22020 A-4.905
    N22025 A-6.331
    N22030 A-7.758
    N22035 A-9.184
    N22040 A-10.611
    N22045 A-12.037
    N22050 A-13.464
    N22055 A-14.89
    N22060 A-16.317
    N22065 A-17.743
    N22070 A-19.17
    N22075 A-20.596
    N22080 A-22.023
    N22085 A-23.449
    N22090 A-24.876
    N22095 A-26.302
    N22100 A-27.729
    N22105 A-29.155
    N22110 A-30.582
    N22115 A-32.008
    N22120 A-33.435
    N22125 A-34.861
    N22130 A-36.288
    N22135 A-37.714
    N22140 A-39.14
    N22145 A-40.567
    N22150 A-41.993
    N22155 A-43.42
    N22160 A-44.846
    N22165 A-46.273
    N22170 A-47.699
    N22175 A-49.126
    N22180 A-50.552
    N22185 A-51.979
    N22190 A-53.405
    N22195 A-54.832
    N22200 A-56.258
    N22205 A-57.685
    N22210 A-59.111
    N22215 A-60.538
    N22220 A-61.964
    N22225 A-63.391
    N22230 A-64.817
    N22235 A-66.244
    N22240 A-67.67
    N22245 A-69.097
    N22250 A-70.523
    N22255 A-71.95
    N22260 A-73.376
    N22265 A-74.803
    N22270 A-76.229
    N22275 A-77.656
    N22280 A-79.082
    N22285 A-80.509
    N22290 A-81.935
    N22295 A-83.362
    N22300 A-84.788
    N22305 A-86.215
    N22310 A-87.641
    N22315 A-89.068
    N22320 A-90.494
    N22325 A-91.921
    N22330 A-93.347
    N22335 A-94.774
    N22340 A-96.2
    N22345 A-97.627
    N22350 A-99.053
    N22355 A-100.48
    N22360 A-101.906
    N22365 A-103.332
    N22370 A-104.759
    N22375 A-106.185
    N22380 A-107.612
    N22385 A-109.038
    N22390 A-110.465
    N22395 A-111.891
    N22400 A-113.318
    N22805 X0.0083 A185.767
    N22810 X0.0016 A186.031
    N22815 X-0.0054 A186.191
    N22820 X-0.0125 A186.245
    N22825 X-0.0625 F20.
    N22830 X-0.0696 Z0.5425
    N22835 X-0.0766 Z0.544
    N22840 X-0.0833 Z0.5465
    N22845 X-0.0895 Z0.5499
    N22850 X-0.0952 Z0.5542
    N22855 X-0.1003 Z0.5593
    N22860 X-0.1046 Z0.565
    N22865 X-0.108 Z0.5712
    N22870 X-0.1105 Z0.5779
    N22875 X-0.112 Z0.5849
    N22880 X-0.1125 Z0.592
    N22885 Z1.225 F400.
    N22890 M5
    N22895 M9
    N22900 G53 G0 Z0.
    N22905 M11
    N22910 G0 A0.
    N22915 M10
    N22920 X3.0688
    N22925 G53 G0 Y0.
    N22930 M30
  18. #14
    Mar 2019
    Washington
    15
    10
    Quote Originally Posted by Em.Re View Post
    Thanks, you bring up a good point. My rotary can only move so fast (relatively slow) and I had my feed rate at 21 ipm. I know I can go way faster with carbide and aluminum, but I ran it the way I did because the part was cantilevered out a bit. Even at 21 ipm, I bet that might have been asking the rotary to rotate faster than it can. I'll drop the feed rate and see what happens.
  19. #15
    Mar 2019
    Washington
    15
    10
    Quote Originally Posted by Bobw View Post
    X)
    no spirals..
    I posted a bunch of code above this post if you'd like to check it out. In Fusion, it does give me the "wrap toolpath" option, so I am only moving 2 axes (x and a). I'm really not sure how to do it using the g107. I'd have to see an example in order to understand that one. But either way, it seems like I'd end up with code moving 2 axes...
    Another guy on here mentioned dropping the feed rate. I'm definitely going to give that a try.
  20. #16
    Mar 2019
    Washington
    15
    10
    Would you happen to have some code generated from this that I could check out? That would help me understand it better. I can wrap toolpath in Fusion 360, so I'm wondering if that's the same thing (although there's no g107) output, just a lot of x and a moves.
  21. #17
    Feb 2005
    9,018
    13662
    10663
    Quote Originally Posted by controlled_burn View Post
    He's talking about letting the machine wrap the profile around the part, not letting the cam program do it.
    Basically program as if in XY, yet you use some code, with a factor for the diameter, and the machine
    substitutes the A axis motion for Y. You may also need to mirror it, but there should be a code for
    that also.. Get rid of all that tiny line segment crap.
    You can see an example for a Fadal. Section 12 of the user manual. Just google Fadal Tech Docs.
    On a Fadal its G17 Qword.
    That should allow the machine to treat your paths as if they are nothing more than a regular
    old G2 or G3.
  22. Likes controlled_burn liked this post
  23. #18
    Jul 2008
    585
    150
    241
    Ive found on my Fadals that having a feedrate on any line involving the rotary axis will cause the machine to limp into DPM mode, for whatever reason.
    Try changing your fast (rapid) feedrate to the same as your desired feedrate.
    Then delete any F values (get rid of f entirely) except your first feed move (before it makes an A move).
    Im willing to bet this cleans it up.
    I have no problems feeding at up to 60ipm on my old falads on the rotary.
  24. #19
    Mar 2019
    Washington
    15
    10
    Interesting... I'll definitely give this a shot and see what happens.
  25. #20
    Mar 2018
    Wisconsin
    76
    20
    18
    In the parameters there is one for A axis diameter, it controls/alters the feed rate for the rotory based on what dia you have in it.I'd try changing that as well , it kind of acts like the override only just for the a axis.
