Haas cmos battery replacement
tommy70562h
Oct 4, 2020
I have a Haas TM1 in storage and bought a battery replacement that plugs into the circuit board. Do I have to disconnect the old battery by cutting the solder or can I just leave it and install the plug in replacement battery pack?
100% must cut out or it can drain your new cells very fast. But, you must first attach the jumper board or else you'll loose all parameters.
I know this as a tech just replaced the battery in my 2004 tm1 when he was here for another reason.
Sent from my SM-G955U using Tapatalk
