Blackmarkit
- Apr 30, 2015
Hi I have a 1999 Haas VF0 that I'm fighting deflection.
Have to make multiple repeat passes to get close to my feature dimensions.
I have installed: all new ball screws in all axis, Z axis linear rails and a new spindle all within the last 6 months.
For example - 1/2 niagra 3 flute 2" loc in Haimer shrink fit .0002" runout
Cutting Aluminum
7500 rpm.
1.5" doc
.020" radial
50ipm
I have 2000 lbs drawbar pressure.
getting .007" off of programmed feature at the top and .013" at the bottom both X and Y are the same.
after running 2 more (spring passes) i was .001" over on top and .0025" on bottom.
Because of the taper it makes most sense that the problem is in Z.
Open to any suggestions.
Cutting Aluminum
7500 rpm.
1.5" doc
.020" radial
50ipm
