HAAS DM/DT MILLS and Brother Speedio Power Requirements
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 85
    Jul 2018
    Washington
    14
    Default HAAS DM/DT MILLS and Brother Speedio Power Requirements
    Looking for owners of preferably a Haas DM2 machine.
    Or a Haas DM1 / DT Machine.
    Current issue is there seems to be quite the confusion as to what a Haas DM2 machine requires for power.
    On the Haas website is reads (see attached):
    ELECTRICAL SPECIFICATION S.A.E METRIC
    Spindle Speed 12000 rpm 12000 rpm
    Drive System Inline Direct-Drive Inline Direct-Drive
    Spindle Power 15.0 hp 11.2 kW
    Input AC Voltage (3 Phase) - Low 220 VAC 220 VAC
    Full Load Amps (3 Phase) - Low 25 A 25 A
    Input AC Voltage (3 Phase) - High 440 VAC 440 VAC
    Full Load Amps (3 Phase) - High 13 A 13 A
    This leads me to believe the machine only needs 25 Amps to run.
    Which would make sense because the Brother Speedio S700X1 needs only 30 Amps and both machines have around a 12-15hp spindle.
    So then I go to ask Haas and they come back to me and say that:
    "They are 70 AMPS and my service manager is comfortable running them at 50 AMPS. We have done full speed demos cutting at our office at 50 Amps."
    Then to add to the craziness. I've talked to a DM1 owner (only a smaller table compared to the DM2) and he says he only uses 30 amps if that and not to worry about what Haas says.
    Any Haas owners out there that have these specific machines? If I cant power x2 Haas machines I know I can power x2 Brothers.
    Thanks everyone!
    Jul 2018
    Washington
    14
    To add to that.
    I have a 200 amp panel for my house with a dedicated 100 amp breaker that I run my phase converter off of that gives me 64 Amps. I could upgrade and get a large phase converter that would give me 96 amps if needed.
    Oct 2005
    12,296
    18684
    6456
    Quote Originally Posted by BrickTactical View Post
    Thanks everyone!
    Who really want's your business ?
    Have both salespeople commit in writing yes/no that the machine
    you want, can be run successfully with your stated power supply.
    Sep 2007
    Washington
    4,830
    118
    1268
    The 16k RPM Speedio is rated for 4.9 kW continuous, 7.4 kW for 10 minutes, so 6.5 HP continuous and 10 HP for 10 min.
    I guess some folks would look at "momentary draw" and make some statements around that (like my 4 HP 110V shopac ). In that case, the 16k RPM Speedio has a 20.5 HP spindle. Woo hoo .
    I can tell you that I have 1000 hours on my S700X1 running off of a 30A breaker, and it has never tripped the breaker.
    Regards.
    Mike
  5. Likes eaglemike liked this post
    Feb 2013
    Northern Mn
    457
    91
    518
    I couldn't get Haas or their recommended phase convertor company to commit to being able to run a DM2 or DT2 off of my 100 amp panel in my shop.
    Sep 2007
    Washington
    4,830
    118
    1268
    27k RPM spindle is 6.3 kW continuous & 8.9 kW for 10 minutes, so 8.4 HP continuous and 12 HP for 10 minutes. Probably would need to look at the curves for this spindle though as you are likely to be running bigger cutters at lower RPM's, where you may not have that much power available.
    Regards.
    Mike
    Jul 2016
    New Mexico
    526
    105
    131
    It's funny because exactly one year ago, the power requirements were 195-240V (3-phase) and 80A (full load).
  9. #8
    Jun 2006
    Near Seattle
    4,489
    2631
    1132
    Get somebody to find one of the machines, and find the power plate (which I think it legally has to have) which will say something like 60amps at 400v 3 phase. (Say.) Then be warned that that plate is supposed to be machine specific and options may change what it says from one machine to the next.
    People not being willing to assure something will work is more likely "we don't warrant anything, we don't warrant gravity is adequate to hold our device to the floor".
    Now there are some other gotchas - check your local code - one is that the full load is not supposed to be more than 80% of the rated circuit - to allow for glitches, special startup loads, and so forth. The details of this are fuzzy to me, check directly with local experts.
  10. #9
    Dec 2003
    poulsbo, wa, usa
    539
    25
    216
    I run a vf4ss every day off a 60 amp breaker feeding a RPC and it works just fine ,,, Haas runs fine on dirty power, its not like fanuc that is picky as hell. I have read some posts about Brothers being picky about there power also.
    FYI Haas VF2 and VF4 only have a 7 1/2 HP spindle motor ,, Haas calls it a 30HP ..
  11. #10
    Sep 2007
    Washington
    4,830
    118
    1268
    Quote Originally Posted by D.D.Machine View Post
    My Speedio didn't like the 240V 3-phase coming out of my Phase Perfect and I had to buck it down. I think the spec is 200-230V +/-10%. While the +10% would seem to allow 240V, my experience before installing the buck transformer was that when running at 16k RPM, once in awhile the machine would fault with an overvoltage error.
    Regards.
    Mike
  12. Likes riabma77 liked this post
  13. #11
    Jul 2016
    New Mexico
    526
    105
    131
    Quote Originally Posted by Finegrain View Post
    Regards.
    Mike
    Same here. I have 240-245V, and I put a bucking transformer to 225V before the Phase Perfect. So far it's working perfectly.
  14. #12
    Jul 2016
    New Mexico
    526
    105
    131
    Yeah, in a 2 year period I replaced the spindle amplifier and Y-axis amplifier because dirty power. Or crappy quality electronic components...
  15. #13
    Dec 2013
    518
    184
    293
    The Brother 16k RPM Speedios are rated 9.5 KVA , 200-230V 3 phase. 9.5 KVA at 220V works out to 24.9 Amps. I had an ammeter on one once and it was running about 15 amps average as I recall with coolant pump and lights etc. going.
  16. Likes DavidScott liked this post
  17. #14
    Jul 2016
    New Mexico
    526
    105
    131
    Quote Originally Posted by BROTHERFRANK View Post
    The only thing I don't like about my Speedio is the tremendous amount of air used. The machine doesn't use too much electricity, but my compressor cycles way much more. My first electric bill will tell!
  18. #15
    Dec 2013
    518
    184
    293
    Speedio S700 16K rpm is rated 1.6 CFM. Check that you don't have any leaks. The spindle purge runs continuously. You may be able to reduce the flow (regulator on pneumatic panel)some to help. Also I have seen people put a solenoid valve on that line so that it only purges the spindle when running parts, shuts off automatically when the machine is sitting.
  19. #16
    Jul 2016
    New Mexico
    526
    105
    131
    Yeah, maybe I have a leak. For sure it's using much more than 1.6 cfm...
    I have 2 separate lines (one for the machine, and another one for the air gun), with barb fittings and rubber hose.
    Do you think push-to-connect fittings and nylon tubing, will be better for leaks?
  20. #17
    May 2004
    Paradise, Ca
    2,337
    767
    1379
    I'm going to look in to putting a solenoid in that line as well. Can you tell us exactly which line it is on an R650?
    Mine, just sitting there powered off but with air supplied will use 10psi every 12 minutes I believe (haven't actually times it), and we have 280 gallons of air storage plus the lines. No idea how to do that math, but I wonder if it's anywhere close to 1.6 CFM?
  21. #18
    Dec 2013
    518
    184
    293
    R650 is rated 1.8 CFM. probably due to the addition of the pallet clamp system. 4th or 5th rotaries can increase air consumption too because they frequently have air purge systems. Here is a pic of the spindle purge regulator and line:
  22. #19
    Sep 2007
    Washington
    4,830
    118
    1268
    Yes, the problem is that the spindle purge is open 24/7 regardless of machine state. Even when depowered the spindle purge is blowing. That seems pretty wasteful to me.
    I would be keen to get details on such a solenoid. If you or any other Speedio owners have that installed, I would very much like to get details.
    Regards.
    Mike
  23. Likes countryboy1966 liked this post
  24. #20
    Dec 2013
    518
    184
    293
    Something like this:
    McMaster-Carr
    It needs a 24V DC coil. You use one of the Mappable Outputs on the IO board. Map an output to Green (Green Light only comes on when cycle is running). Connect solenoid to the output and put in line of spindle air purge. Voila!
  25. Likes Jashley73 liked this post
