a search produced no results. I have the red grease with no pressure gauge, which according to HAAS is the GREASE, REFILL MOBIL SHC 007 - 1 QT. front of panel confirms is Mobilith SCH-007
Looks pretty straightforward (at least until you run it dry, which i haven't done, then you need to do an air-purge). A quart of grease is 20 bucks.
Anything unexpected or do the instructions cover everything pretty well?
thanks
Minimum Lubrication - Axis - Grease Reservoir - SHC007 - Refill - AD0011
thanks
