brokenrinker
- Jul 6, 2012
- St. Louis
Using a G71 roughing cycle followed by G70 finish cycle. The tool path uses G42 compensation and ramps off (G40 with a X and Z move) after the "Q" block.
I've got a program stop after the ramp off so I can check dimensions prior to the finish cut. The control keeps saying I can't use a program stop with cutter comp engaged? Comp should have been turned off?
